180 smoke and miss |
Author | ||
marzer ![]() Bronze Level ![]() Joined: 08 Dec 2014 Location: Saginaw valley Points: 37 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Oct 2020 at 9:55am |
My 180 smokes gray with a miss. When #4 line is loosened the smoke goes away. We pulled the injector and had it tested by a local diesel injection shop. The old boy running the shop said it tested ok. The pump was rebuild before I bought the tractor but I don't know how long before. The smoke occurs throughout the rpm range. It has smoked for the two plus years I have owned it. Any help determining what is wrong would be appreciated.
Sponsored Links | ||
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9803 |
Are you loosing any coolant? Any bubbles in your radiator?
No bubbles or coolant loss.
Amos ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ontario Points: 1318 |
Low compression...maybe a valve or a sleeve/piston/ring issue...or cracked head...
Edited by Amos - 10 Oct 2020 at 2:11pm |
Boss Man ![]() Orange Level ![]() Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
I would do a compression test and check valve lash.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21726 |
Swap that injector with any of the other ones. If the smoke is still there and goes away when you loosen #4 injector line, you have a compression problem on that #4 cylinder.
Edited by DrAllis - 10 Oct 2020 at 5:23pm |
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
I've seen posts about "valve lash". I just can't wrap my head around why the valves are more of an issue vrs. cylinder rings/ head gasket issues ??
ksbowman ![]() Silver Level ![]() Joined: 19 Mar 2013 Location: Paola, Ks Points: 228 |
Thanks Kman
Valve lash can go 1 of 2 ways. To tight and valves may not close completely causing compression lose and eventual burning of the valve. To loose and they aren't fully opening there fore restricting fresh combustion air coming in or not allowing all exhaust gas's out causing the cylinder not to have enough clean air to burn the fuel charge.
Thanks for the replies. I adjusted the valves last winter when I repaired the valve cover leak. I was planning on doing the injector swap. The pump shop guy said to check the pump timing and if the flex ring going the pump will do some weird .... stuff. I will swap injectors and see where that takes me.
Generally, when there is a serious compression loss problem on ONE cylinder, a trained ear can hear that when cranking with the starter.
I will swap injectors and I will listen for something strange in the exhaust. The engine has very little if any blow by. Hard to believe compression is going past the rings but who knows. I will keep digging. Thanks.
^^THIS^^
I finally had a chance to run a compression test on the 180. I plugged in the block heater a few hours before I started to warm up the engine. Cylinders 2-5 were all 330 psi. 6 was 340
and 1 was 370. I don't know why 1 is soo much higher. I still need to check the pump timing and will do the injector swap when I put it back together. Starting to be a head scratcher. |
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5087 |
The injector may have "tested ok" but is it really ok? I've seen many times where they seem to work ok, but once I take them apart to inspect internal parts, I find problems. He should have taken it apart too. You may discover the injector is at fault eventually when you swap it with another cylinder. I can't imagine the pump causing this one cylinder issue, even when flex ring fails, they will miss random cylinders, never seen just one.
Sounds like the injector cylinder swap should point me in the right direction.
I've been tinkering with the 180 again trying to fix the high idle hunt issue. While aligning the timing marks in the pump I noticed rotational free play of the weight retainer. I'm curious if this would cause the ruff high idle. I have video but don't know how to post. Thanks
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3511 |
180's were set to high idle at 2000 , above 2000 the timing was not advanced enough to prevent flutter on many. The 185 was 2200 and had the hydraulic advance to cure this - just a comment.... IF the 180 was set too 2400 most I have seen do 'flutter'.
3010 John Deere diesel does the same thing. Wide open throttle in road gear going downhill the engine flutters and as soon as there is some load put back on the engine, it goes away. If you can wiggle/move the governor weight retainer thru the timing window, I'd say it's probably time for a pump overhaul.
Looking at the pump drive shaft it appears the weight retainer has been wobbling for awhile. Probably need a new weight retainer when the seal kit goes in.
This explains a lot.
Red Bank ![]() Orange Level Access ![]() Joined: 18 Apr 2018 Location: Germanton NC Points: 1051 |
Am I looking at that right? The valves are in the wrong spot?
Yup. This was not an easy one to figure out.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8308 |
Oh my my my - interesting !
Now who the heck done that!!!!?
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8568 |
Rebuild head and pump and should out last you. (new valves)
The valves where contacting at the very top edges. I don't know how it ran so long without burning the valves. The plan is to clean everything up and check contact. If it had a valve job, the interference
should be ok. |
