New WD
Leonard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Topic: New WD
    Posted: 14 Nov 2010 at 6:26pm
Hi all, I bought a 52 or 53 WD off craigslist today for $500.  Tractor is a n/f and has been converted to 12v.  What I would like to know is how difficult is it to change from n/f to wfe.  I have a wfe off a WD45 at my dad's, so no problem for parts.  Will a wfe off a WD45 bolt right in or are there modifications that are going to be needed?
Sorry for no pic's am in the analog age with only a 35mm film camera and forgot it today.
Thanks
Leonard
Edited by Leonard - 14 Nov 2010 at 6:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 6:57pm
Having a complete parts tractor available to do the swap sounds like you have everything needed except elbow grease. Seems like I've heard that there are "3 bolt" and "4 bolt" WFE's. You might end up swapping the complete front bolster assy.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 7:17pm
There is no doubt about it.
You have to swap out the front bolster.
Remove 4 bolts on each side, disconnect the steering shaft, and slide the bolster endways out the front.
Gary
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 7:32pm
Yeah, them 4 bolts like to twist off so use caution to avoid having to extract the broken portion out of the casting. Sliding" the bolster out the front is also sometimes a challenge.  Spreading the frame rails a bit makes it easier and doing that is easier if the engine is out of the frame.
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 8:10pm
It makes no difference if its a 4 bolt or a 3 bolt  to you if you have a parts tractor.  Its just a matter of how the front axle pivot bolts onto the steering gear.  Same amount of bolts in the framerails and everything else.   I switched out a mangled up 3 bolt for a 4 bolt and it went right in.
I think the 4 bolt came into being when the diesel was offered in the 45.  The gear had to be shorter to accomodate the 6 cylinder and the front bracket needed a little more beef to account for the extra weight.  Dont quote me on that though, just a guess.
Edited by Roddo - 14 Nov 2010 at 8:13pm
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 8:38pm
just put a wide front on my formerly nf WD45....simple swap.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2010 at 4:56pm
Ok guys, finally g home last night.  In my inspection and research of this tractor it seems that it is a '53 model with a straight shift according to the sn.  The sn on the left rear below the brake housing is WD153917 and engine sn is WD264982GA.
Also, the tractor has a pin hitch that is going to be changed to snap coupler in the spring.
Any info will be greatly appreciated.
Leonard
