1936 ac wm crawler
wcc5595@gmai.com View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wcc5595@gmai.com Quote  Post ReplyReply Direct Link To This Post Topic: 1936 ac wm crawler
    Posted: 07 Jul 2021 at 6:59pm
Im trying to get a ac m crawler to run and need parts can someone help me
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 5:43am
Welcome to the site
It will help greatly if you can describe what you have done to it to date and what parts you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wcc5595@gmai.com Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 5:45pm
I bought this beautiful old allis Chalmers crawler. The radiator and head were off with most of the parts accounted for. The front piston was froze and in time I was able to remove it. The piston was tore up in the process. The sleeve is pitted and rough and comes out tomorrow, I hope. I sent the head in for a valve job. I should have it back tomorrow. The zenith carb is being rebuilt by a local shop in Cottonwood ca. I think I should have the magneto checked as well? The crawler is in good shape but for the engine. I can’t tell what I have until I get it running. For now I have the manuals and a list of parts as follows, one piston and rings and sleeve, all the gaskets I can get my hands on and a place to send my mag to. I have other part need but that would get it running and then list will probably expand. The frame # WM 3796 and motor #UMA 3917G
Thanks for the concern. Im not familiar with this or any Form so please be patient with me. Any help would be appropriated
Sincerely,
Bill Culmer
On Jul 8, 2021, at 3:53 AM, Unofficial Allis <noreply@allischalmers.com> wrote:
Post Options Post Options   Thanks (0) Thanks(0)   Quote wcc5595@gmai.com Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2021 at 8:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote wcc5595@gmai.com Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2021 at 9:00pm
the number on this ac crawler engine is UMA9317G but Im unable to reference is number to any active parts list.  Im lost with my rebuild and could use help.  I can answer questions and send pictures.  thank you
Ray54 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2021 at 9:09pm
Many know more than I about old engines, but think that engine was used in a wheeled tractor of the same time. Maybe a model U , hopefully somebody will know. Because that could open up the parts search a lot.
If you get real desperate just learned of a place making one off pistons in LA Calif, and another was also mentioned. Olson gaskets in Washington state can make head gaskets.
Not to insult you but without a teacher you never learn as fast and easy. Do you know about making paper gaskets with a ball peen hammer. If not look for you tubes explaining the process.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2021 at 9:27pm
Just looking the Farm Equipment section over and a question on a M radiator cap is showing and it says a model U one should fit. So my guess about a U and M being the same engine is looking better. So maybe ask your M questions there where there is more traffic will get more answers.
Bob (IN) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Bob (IN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2021 at 6:25am
mark Pfouts should be able to get you all the gaskets and other parts his number is 440 570 3653
great-grandpa's wc with picker, 20/35, speed patrol, uc, m crawler, 620, 653 dozer d21 d17 d19
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2021 at 10:37am
When you get to the manifolds be sure to check the sleeve above the carb, they are well known to disintegrate over the years. Somebody has done a great deal of freeze break repair, that gives it character as long as it doesn't leakWink  I have often wondered for obsolete head gaskets if a person could duplicate the dimensions  on CAD and then cut them from copper and anneal them, add a fine film of RTV and you are in business.  Good luck with your project it will be great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wcc5595@gmai.com Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2021 at 2:18pm
thanks for all you help
