Tractor recomendations |
| Author | ||
TomYaz
Topic: Tractor recomendationsPosted: 12 Jun 2021 at 5:12pm |
Ok so I am now an Big Time Operator orchard man as I have done by second pass of my orchards with a 100 gallon air blast sprayer in the D17.... The D17 Is just heavy enough to handle the 100 gallons...I would prefer a heavier tractor. The hand clutch is a no go. Because of how I spaced my trees, I need to constantly shut off and on the electric spray switch with one hand, drive with the other. To not do so will waste a lot of spray. Also there are times when I want to do a tree slower utilizing the hand clutch so to keep PTO going but My hand is too busy. So what I need is a tractor that is a bit heavier, AND one that allows me to "creep" when I need to with a foot clutch (one that is built for such activity) whilst keeping the PTO going. Is there a AC that fits the bill, or another brand? Tom
| Sponsored Links | ||
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55306 |
Posted: 12 Jun 2021 at 5:34pm |
Put the on/off switch for the sprayer on the top of the PD lever...
TomYaz
Posted: 12 Jun 2021 at 5:53pm |
![]() What I want in riding the clutch other than the hand clutch is not to be found or not good for the clutch I suppose. I guess in modern terms what I want is a I tractor with hydro ground speed control and independent PTO. ...Run the sprayer switch with one hand, hydro ground speed and steering on the other. Going slow and straight and with power steering I would think the one hand could do both. |
matador
Posted: 12 Jun 2021 at 6:04pm |
I don't know what your budget is. If you can afford one, an International with a Hydro would probably be the cat's meow for you. If you can't, and are looking at something with a gear drive, I'd look at an old Case with Case-O-Matic (730 or 830). I bought an 830 last month and love it. You can crawl along slow in the Case-O-Matic mode, but the way that system works makes it so you can almost drive the tractor with the foot throttle like it's a car. If there's a large load, you release the foot clutch and the tractor will just sit there until you give it throttle. C-O-M is a torque converter system, so a high load with no throttle means you sit there just like you would in your pickup. It's not an Allis, but for what you're doing it might be just the ticket
TomYaz
Posted: 12 Jun 2021 at 6:33pm |
Thanks for the tips! I do have an AC175 that is not going to do the job...part it out to raise a little $$!
bigal121892
Posted: 12 Jun 2021 at 6:44pm |
Assuming a tractor with CVT isn't in your budget, then I would go with Matador's idea.
matador
Posted: 12 Jun 2021 at 6:49pm |
I'm probably wrong (It's my specialty!), but the IH Hydro is the only true older Hydro I can think of. For what you're doing, a Case-O-Matic would make a lot more sense than something like a Deere Powershift I'd think. Those old Case's go pretty cheap if you can find one in decent shape usually- a lot of people don't understand how to run a Case-O-Matic (Not all 730's and 830's had it- it was an option), so they don't bid on them. It's simple, but different for sure
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5192 |
Posted: 12 Jun 2021 at 6:56pm |
How about an AC 7000? Independent PTO, three shifts (low, medium, high) on the go in every gear. It's heavier than the D-17, but still pretty nimble. Reliable turbocharged 301 engine.
I loved my 7000. I think it's just what you are looking for ! |
TomYaz
Posted: 12 Jun 2021 at 8:00pm |
Didnt realize what I was after was such a "special" feature!
I have one hydro tractor...a Deere 316 garden tractor...love the hydro feature.... Hell WF I dont know what the hell I want! Or, watch what I ask for, I just may get it! |
TomYaz
Posted: 12 Jun 2021 at 8:05pm |
Oh hell thinking this through....outloud...
Let me put the sprayer switch on the left hand next time......see if its easier....
WF owner
Posted: 12 Jun 2021 at 8:31pm |
Or maybe a peddle switch?
Posted: 12 Jun 2021 at 8:44pm |
Foot switch, yes like a real big time sprayer has.
TomYaz
Posted: 13 Jun 2021 at 9:38am |
Wait a minute....I was told I was buying a real big time sprayer, and I have no such foot switch! I have been had!
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8995 |
Posted: 13 Jun 2021 at 10:14am |
"life lesson"
