RA / RC TRACTORS |
ianreikie ![]() Bronze Level ![]() Joined: 09 Nov 2010 Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Nov 2010 at 1:28pm |
I have one of these ane i would like to find information on these units
DonDittmar ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2513 |
The RC is a WC chasis with a model B engine, plus a low geared rearend to help the smaller B engine out. Was Ac's 1st attmept at a low cost 2 row tractor, did work out. Eventually replaced by the model C
what about the ra model when i got this tractor i was told it had a ra combine engine??
Andrew Kimbrough ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Minneapolis, MN Points: 283 |
hmm.. I dont think there is an ra in the allis tractor or combine line.. unless somebody else knows something on it that I dont.. Could it be a CA tractor? If you post pictures surely somebody could identify what you have
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Combine engines were CR engines. Look at the engine serial # on the left rear flange by the air cleaner. The RC would have had a CE engine originally. see what you serial # starts with. Bob
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
AR combine
Chad(WI) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: NE Wisconsin Points: 957 |
The RC would have a R engine originally.
Ken in Texas ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Bump
Mine has the wc style frame and had the hand brakes but the newer style gas tank and has electric start
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22824 |
All RC's were styled and had hand brakes. Probably all had electric start too.
On the RCs. Is the Engine SN easy to read? I guess what I'm asking is, if it easy to see it would be on the top edge left hand rear flange of the cylinder block. If that is the case it should not be a original 125 RC engine which should have the SN on the back of the block. Am I correct in assuming all the RC engine SNs were stamped on the back of the block?
GreenOrange ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Wisconsin Points: 843 |
No RC engines were stamped on the back of the block, they were on the left side flange. They have an R prefix, as said. Electric start was an option, not standard.
-John Edited by GreenOrange - 11 Nov 2010 at 8:05pm |
So if an RC had the original engine and had electric start, you would just about have to remove the starter to read the engine number?
I edited my post to be more clear.
WC7610 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Sioux City, IA Points: 764 |
Charlie, The engine serial number is on the bell housing right by the air cleaner. |
Thanks
Most Bad Government has grown out of Too Much Government- Thomas Jefferson |
During the years the RC was built with the so called B engine, which was in reality not a B engine. B engines in 40 and 41 were 116 inch displacement BE engines and the RC had a 125 engine.
The C came out at the same time as the RC and had a 125 engine.
Recent posts of the low number early Cs show the engine SN stamped on the rear of the block like the Bs with BE engines of the same vintage.
The question came up about the location of the engine SN on a RC. Specifically RC #9
Terry Deans AC Data book places the engine SN on a RC to be "Rear of Block".
The R prefix engines according to AC dealers part catalog dated June 1964 is described as engines in 3-3/8 bore 60H power units both gasoline and low octane.
What is written and what is real seems to be in conflict. Just trying to clear up what is for real.
RichinWis ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Deforest Wis Points: 691 |
Two things have to be remembered, 1 the R engines predated the C tractor, and 2 the R engine was the first of the 125 cu in engine. I'm sure because the RC needed all the help they could get.
I thank all the posts on this subject. I will have to do some looking this weekend to find out where the SN is and what it is for sure. I also would like to know if there is literature on line that can be read or is it just in books for purrchase. Thanks again for all the info
MNLonnie ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
Here is a good site with lots of info.
Tractordata.com also has some more info.
The "rear of block" may be referring to the left side mounting flange at the rear of the engine... or it could be just wrong (like you'll sometimes see the tractor # location on a U listed as on the top of the transmission). RC#9, specifically, does not have its original engine - it has a later engine. I have seen a few R engines in power units, but they were all later than the RC tractors.
Edited by GreenOrange - 12 Nov 2010 at 5:03pm |
1946WP ![]() Orange Level ![]() ![]() Joined: 25 Apr 2010 Location: mn Points: 780 |
I have 2 rc's ,both have r engine serial #'s located on the engine flange by the air cleaner.
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3865 |
I used to own RC #8 the engine# was R12G and was stamped on the engine flange, the tractor was at Rolog this past labor day and the present owner gave me the privelage of driving it through the parade.
Mark, if your number was that low and on the flange maybe all the RC engines were that way and just the early CE's were on the back.
