WD45 Duals?
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Duals?
    Posted: 11 Nov 2010 at 10:43pm
I've never seen these before....I'd be all over them but then my WD wont fit on my trailer anymore.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2010 at 10:43pm
I guess the link would help hahaha http://cgi.ebay.com/Allis-WD-WD-45-Dual-Duals-Wheel-Extensions-Rims-/370176422138?pt=LH_DefaultDomain_0&hash=item56303bf0fa
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2010 at 10:44pm
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2010 at 11:20pm
Is that oem or somthing built to work ?  thanks for info, I was wanting to put duals on my 56 45 diesel this spring and was wondering the best way to do it. I have looked in my parts book and dont see anything about dual rear wheels.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 12:56am
Dad used to have duals for his 45 (14.9-28), He's told me stories of when he was younger about them. It was a wet year, Grandpa had a D-19 wf with 18.4-34 deep tread firestones and a 9ft disc. He got about got stuck and had to raise the disc to get out. Dad came through the same spot with a WD-45 nf with duals 11ft disc (which we still have) and disked grandpas tracks out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 7:23am
I used to run duals on my 45 diesel every spring discing plowed ground with a 12' Krause wheel disc. worked great.  People used to stop along the road and watch.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 7:48am
Those look to be homemade,  they might work if you wanted the dules on all the time. The best would be some clamp on dules.  You put some eyes on the rales by either welding or bolts, and then clamp the dules on with the hooks. They can be either bolt or snap overcenter type.  They are not hard to find.
This page was generated in 0.058 seconds.
