WELD HARDENING |
Tad Wicks ![]() Orange Level ![]() ![]() Joined: 27 Mar 2011 Location: Shandon, CA Points: 2175 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Jun 2021 at 3:01pm |
I do a considerable amount of salvaging older or no longer available parts and pieces and one problem that I have yet to solve completely is weld hardening of the base pass buildup on cast and forged steels. I have tried numerous rods, wires, pre-heat and cool down to try and alleviate the hard spots but they still show up and eat carbide like beavers eat trees during the machining processes. A friend of mine worked in construction and said any time the line boring guys showed up that they would do a base pass of 7014 before anything else, I haven't tried that yet but thought that I would give it a try with DC- to try and not disturb the bass material any more than necessary. Anybody have any tricks or tips? Thanks
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 42010 |
On cast I have used Allstate #8 rod , or in some cases a 304 SS rod - then depending if a BUILD UP is needed following with a 7018 rod as filler or using E 70s wire feed
On cast a pre heat is needed but I have also used brass with oxy/acc for joining but then no metal rod beyond . I had bought 3 axles for HD4 that had been welded up at seal location then machined but found the welding and machining destroyed the integrity of hardening and relieving and of stress and axles broke and a crystalline feature of axle showed - so I uses speedy sleeve to correct wear on used axles with no more breakage . Problem on cast can be the carbon deposits which come from base and then contaminate any machining done . Son has noticed new steel he has been purchasing is heavy with carbon deposits and is heck on saw teeth when cutting - doesn't seems to effect fabrication welding but sure is something if any machine work is needed on the raw steel before welding . |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88274 |
i weld everything i do with 7018 on DC... Never used the 7014 rod, but it is suppose to be a FAST FREEZE meaning it does not burn in as much as 7018, more sets on the surface and cools faster... Maybe that is the plan in not drawing in the carbon.. I dont know.. I do know the 7018 does draw, but i dont " machine" much after welding... more justs buildup and repair broken... My machining is normally a grinder.
I always figured 7014 or 7024 as a drag rod for flat welding or filler rod - I welded the grouser bars on my HD5 track with it as well as grousers on D5 track I installed on my D6 -9U .
https://youtu.be/vlwmE0Naxkg Edited by Coke-in-MN - 03 Jun 2021 at 7:06am |
ac-mike ![]() Silver Level ![]() Joined: 14 Sep 2009 Location: Kentucky Points: 278 |
For build up work that will be machined, I have always used #6013 for steel applications. I know this is not the strongest weld but it does machine.
D-12III, 200D, 170G, HD-3, D19D 3pt, D17D High Crop, WD45G p/s, D15IID, D15IIG, D15G IND, 655, (3)WD45D p/s, 700, 816
Lee Bradley ![]() Bronze Level ![]() ![]() Joined: 13 Oct 2009 Location: Kingston, WA Points: 120 |
Some videos here well worth the time.
