electric motor help
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: electric motor help
    Posted: 21 May 2021 at 6:20am
OK, it's too hot here for me to think......
Air compressor(powermate,60g,155psi,3.7rhp) 'died', Century AC motor(4HP, 230x 15), will start, run but NO torque. it  stalls/growls when belted to head( head NOT siezed...),belt  tension fine.
I suspect the 'run' cap even though it 'runs...'. According to manual it's 25mfd/270 yet it says 20mfd .
So cap is $189 ! choke, new 3HP motor is $200. 5HP is $350 but need to rewire power...
Naturally ,sine the move I can't find my stash of motor caps....grrrrr
looking for any advice, options, ???
thanks
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 8:52am
capacitor might be the problem.. I normally look on e-bay and find one.. Sometimes identical, sometimes CLOSE.. Being off a little on the START capacitor will vary the time ( milli seconds) to get to speed... Not sure what changing the value of the RUN capacitor would do, but probably varies the PHASE ANGLE that would effect the TORQUE..
I though capacitors were about $20 ???
from GOOGLE.........
run capacitor is used to continuously adjust current or phase shift to a motor's windings in an effort to optimise the motor's torque and efficiency performance. Because it is designed for continuous duty, it has a much lower failure rate than a start capacitor.
Edited by steve(ill) - 21 May 2021 at 8:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 8:55am
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 4:10pm
What a timely thread to post as I have a sweep auger that runs but won’t start on its own. Have to “kick start” it to operate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 4:48pm
you need the START capacitor... if will look similar, but very different numbers.. nott 20 UF.... normally  100-200-300  type numbers.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 6:53pm
Yours should be under the bubble cover on the side of the motor, it should be black and round.  As Steve said, should be something like; 88-108, 108-130, 130-145mfd, and then probably 110vac, 220vac and so on.  The larger the vac the larger the diameter usually.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 7:40pm
Single Phase motors have a centrifugal switch that is part of the starting system. I've seen the springs on that switch break.
Dusty
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2021 at 9:38pm
If you get a new motor, make sure it is rated for air compressor use. Farm duty motors don't last very long on a compressor. If you have yours rebuilt, make sure you tell the rebuilder it is for your compressor. Speaking from experience owning a tire shop for 22+ years.
