White tractor Fuel injection |
bobkyllo
Joined: 14 Sep 2009 Location: minnesota Points: 1572 |
Topic: White tractor Fuel injectionPosted: 10 May 2021 at 8:12am |
I know it's the wrong color, but allis shares many of the same parts I'm struggling with.
My white 2-70 the pipes hooked on the roosa master injection pump leak. They have ever since I got it back from the repair shop. I'm referring to the little short pipe that's held on with a banjo bolt. The injection line screws on this. Also I noticed that my return line keeps leaking. I'm having a lot of trouble with those rubber t boots that connects one injector to the next. Any help on either problem would be great. When I get this fixed I've got a line on my 2-135 white that needs to be replaced. I think it's cracked. I can loosen the nut at the injector then tighten it again and it will be fine for a little while. |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5199 |
Posted: 10 May 2021 at 9:07am |
Did you use new copper washers on both the inside and outside of the injector lines? It's imperative you use new ones every time you remove them.
bobkyllo
Posted: 10 May 2021 at 11:15am |
I believe he used aluminum??? I'm not positive. I know he used new ones but I'm certain they were not copper. Will copper be ok with diesel fuel?
Boss Man
Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
Posted: 10 May 2021 at 4:54pm |
A lot of engines use copper.
HD6GTOM
Posted: 10 May 2021 at 8:33pm |
Every one of them I've been around including AC, Oliver, JD, and IHC use copper washers. I've never seen aluminum used for this purpose.
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9005 |
Posted: 10 May 2021 at 10:50pm |
Well....you can't get a normal torque wrench on them on the back side but I think my 220 service manual says something like 35ft/lb on them. Though they were tight with hand wrench but tried the T/W and they went a good bit more. Maybe you don't have them TIGHT!
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5208 |
Posted: 11 May 2021 at 12:40pm |
Those washers are supposed to be steel, and I tighten them as tight as I can get with a regular 9/16 wrench. A 2-70 is a 1655 with a new dress, great little tractors!
Posted: 12 May 2021 at 10:05am |
As Ed says,the latest are steel
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8412 |
Posted: 16 May 2021 at 12:47pm |
On related note, is a 2-135 basically the same as MM 1355?
injpumpEd
Posted: 16 May 2021 at 3:05pm |
Not at all. A 2-150 is exactly the same as a G1355 except sheet metal/cab, and some updated issues. The 2-135 and 2-155 are the same basic tractor as one another, but was a totally new design, larger trans and rear end with inboard planetary final drives and wet brakes. This drivetrain is what they used for a long time afterward. The DA 9130, 9150, 9170, 9190 etc. Great drivetrain! The 2-135/155 shared the Hercules engine 478 cid from the oliver 2050/2150.
