D17
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Topic: D17
    Posted: 04 May 2021 at 7:23pm
Hello I’m at a crossroads where to go. I purchased a D 17 that was locked up took the head off and found number three cylinder liner was cracked in two spots. It was pushed into the water jacket area I’m guessing water got in the cylinder and froze during the winter time. The tractor is in pretty good shape and I hate to part it out but I don’t want to dump a lot of money into redoing the whole motor. Should I just pull the motor and replace one sleeve and put it back together or just put a whole new kit in it. Btw i’m looking for a whole set of valve retainer caps for it. Thanks jlogli.
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2021 at 7:48pm
I have a B that was similar 15 years ago.. I bought a used sleeve for that hole... Bought all new rings , lapped the valves, reshimmed the rod and main bearings, new gaskets... all back together running great.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2021 at 9:13pm
Don't know how big your bank account is.            MACK.
This page was generated in 0.037 seconds.
