AC 6080
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Topic: AC 6080
    Posted: 14 Apr 2021 at 8:06pm
A very very nice 6080 for sale on Omaha craigs list
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2021 at 6:22pm
My father in law looked at it. It’s got a few issues. Injection pump was leaking. I forgot what all else he said. Pto clutch has been pulled back for months since it’s been for sale. They want one bad but he passed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 6:39am
Little high on the price IMO
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 8:38am
Rear tires are very worn.  No fluid in rear wheels, so traction won't be too good.  Interior of cab is missing a couple of the fans for heater/air and temp control won't move so don't know if air or heat work.  Did run and drive pretty nice, but yes I agree, price is on the high side.
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2021 at 10:45am
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2021 at 9:29pm
The pto lever pulled back is the big issue for me on a otherwise decent 6080. Yeah the cab is a mess but a cab kit would fix that. Knowing the AC/heat work would be another issue also. Would take quite a bit of money to fix any of the possible cab issues, plus running a 6000 series with the pto lever back all the time would make me walk away also. A shame, the exterior of the tractor looks pretty decent. Price wouldn’t be to far off if none of those issues were present IMO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2021 at 8:47am
What does it mean that the PTO clutch/lever is pulled back all the time?  I'm not familiar enough with the 6080 to understand this.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2021 at 10:04am
Its a PTO disengagement lever. It puts strain or thrust on the crankshaft causing failure. There was a service topic on it where an external crankshaft thrust bearing was added
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2021 at 11:02am
we have a 6060 with the added front thrust bearing that was installed in the 90's
being that the tractor is at a nursery it has may different operators. These guys never leave that hand clutch disengaged. Unless there mowing with it.
tractor came into the shop in March of 2019 with 11687 hours for a engine rebuild and the crankshaft end play was still with in specs.
engine had a ton of blow-by was the reason for the overhaul.
we purchased this tractor new and this was the first rebuild on it.
tractor is serviced every 100 hours.
used for mowing, pulling wagons and running a field cultivator.
D15 SER.2 DIESEL
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2021 at 2:25pm
Apparently the thrust bearing kit did its job in your case. Quite surprised you haven’t had to replace the bearing there so someone has definitely been keeping it greased. Good to know they do work long term.
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2021 at 5:27pm
Must have sold, listing pulled by seller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2021 at 6:19pm
6060,s never had issues with that failure- just 6080,s - Ive heard
Edited by DougG - 21 Apr 2021 at 6:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2021 at 10:04am
It was both models, they used the same engine, 6080 was just inter cooled. Some got the bearing support and some did not. Our dealer did not let us know there was an issue and dad never received a bulletin from AC which is very disappointing. If the pto disconnect is used properly it shouldn’t be an issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2021 at 8:14am
Looks like it is sitting on the lot at Osceola Implement in Osceola Nebraska.
This page was generated in 0.281 seconds.
