H3 Clutch Pedal
randymcc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randymcc Quote  Post ReplyReply Direct Link To This Post Topic: H3 Clutch Pedal
    Posted: 19 Mar 2021 at 9:08am
Restoring a 1963 H3 and working my way from front to back.  Latest problem is a clutch pedal that barely moves.  It is essentially frozen and there is no way pedal return spring can move it.  The pedal is disconnected from the clutch rod.   Does the clutch pedal rotate on the torque housing shaft or does the shaft itself rotate?  Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2021 at 10:24pm
If the pedal has a snap ring holding it on, and a grease zerk, I would guess it pivots on a slid shaft pressed into housing. HTH Tracy
jemoore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jemoore Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 7:00pm
Would someone please post a picture of the foot clutch pedal linkage. I'm restoring an H3 and one of the many problems, the pedal is not attached to anything. I cannot find anything that is broken so I do not know where to reattach. So far I have replaced everything in the rear end: steering clutches, brake bands, final drive seals and bearings. I would like to get the pedal attached before putting the tracks back on.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2021 at 12:51pm
Reading in 'Operators Instructions' for H-3, it reads similar for Engine Clutch Adjustment for a Model D-14 or D-15 Tractor.
It states "disconnect the Clutch Rod from the Pedal, shorten the Clutch Rod by turning Clockwise until there is 1/2" of free movement of the pedal link rod when measured at the side of the Torque Housing.
Sounds like yours is missing the Clutch Rod, which can come disengaged from the Pressure Plate Lever if turned Counter Clockwise too far when adjusting for clutch wear.
G
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2021 at 5:07pm
If a H-3 has a shuttle clutch, the foot clutch is rarely used. I only depress the foot clutch to make it easier for the starter to spin the engine to start. I find the neutral spot on the shuttle to stop the transmission and then shift to a different gear without any grinding.
Likely why the linkage is disconnected or seized.
This page was generated in 0.180 seconds.
