8070 transmission oil cooler |
ajl ![]() Bronze Level ![]() Joined: 31 Dec 2009 Location: Alberta Points: 115 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Apr 2021 at 8:43pm |
Is there a transmission oil cooler on these tractors? There is a small cooler mounted in front of the radiator at the top and I assume that is for the hydraulic oil but I don't see another one for the transmission oil. Was out this week busting up an old pasture with the tractor and it was pulling fairly hard and the trans oil temp light came on. I shut it down and let it cool off and then the light went out and I finished the job and it didn't come on again. Given that the the reservoirs are separate I expected two coolers.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21819 |
It is a twin cooler. If you look closer there are FOUR hoses going to and from it.
