D grader shift pattern |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5226 |
Topic: D grader shift patternPosted: 29 Mar 2021 at 7:28pm |
I've seen a picture some time ago of the gear shift pattern on a D grader. I'd thought I'd saved it, but now I can't find it. Would someone please post a picture of the D grader's gear shift pattern? Thanks
Edited by PaulB - 29 Mar 2021 at 7:28pm |
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54968 |
Posted: 31 Mar 2021 at 5:48am |
Paul, will this do?
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8871 |
Posted: 31 Mar 2021 at 9:55am |
WOW!! That's a crazy pattern! Be a tuff one to fiddle with and figure out.
PaulB
Posted: 31 Mar 2021 at 10:05am |
That works. THANKS I knew where 1st & reverse were as they are about the only two gears the grader has power enough for.
DonBC
Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 947 |
Posted: 31 Mar 2021 at 5:54pm |
They were geared too fast. They did make a reduction gear box for them but I was never able to find one for mine. It is a good thing the engine had lots of torque because I was often working with engine at a fast idle.
Ross D.
Joined: 02 Sep 2013 Location: Erin, Ont. Points: 339 |
Posted: 01 Apr 2021 at 7:52am |
Good morning. If you have the auxiliary transmission, you can drop your ground speed in each gear by 66% (not 10%, not 15%, not 20%; but, 66%). Wow, what a difference this makes on your R P M's.
My 1967 'D Special' with hydraulic brakes, which will be for sale later this week in Ontario, Canada. Ross D.
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4577 |
Posted: 03 Apr 2021 at 4:01pm |
Ross !!! Are you going to sell my baby ????
DonBC
Posted: 04 Apr 2021 at 3:35pm |
Ross, I hated to part with mine but I didn't I didn't think it would fit that well when we moved to a city sized lot or get much use on paved streets. You must be moving?
Robert Z
Posted: 06 Apr 2021 at 10:26pm |
good day all. I have a D1598. It has been sitting for a long time. It ran when parked but the engine is stuck. Any advise on getting it turning again?
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25046 |
Posted: 07 Apr 2021 at 5:37am |
Assuming it's gas.... basic list.... 1-remove plugs 2-add 50/50 mix of acetone and ATF to all cylinders 3-wait a day 4- repeat 2 and 3 for a week drain tank and carb, see everything is 'free', charge batteries, etc. while waiting.. 5-blow out cylinders,connect battery,try to spin over 6a- no spin, goback to 2-3-4 6b - spins ! add plugs,fresh gas, try to start |
Robert Z
Posted: 07 Apr 2021 at 8:34am |
Thank you so much. Yes it is a gas.
How much do I put in each time? Is a ounce to much? Do I need to worry about getting acetone fumes getting into the crank case? Or does the ATF stabilize it enough. RZ
