serial number
gramps tractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gramps tractor Quote  Post ReplyReply Direct Link To This Post Topic: serial number
    Posted: 29 Mar 2021 at 8:08pm
wd45 has wd 63 36,seems like I am missing a couple numbers. Trying to figure out the year.Help would be appreciated.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 8:21pm
No WD-45 Tractors would have a Tractor Serial Number like you list.
WD-45 Serial numbers continued on from WD Serials.
The first WD-45 Serial was WD146607, continued all the way up to around WD236958.
Did you get this number from the rear of the tractor.
see attached Link
G
http://wsmth.people.clemson.edu/SNLocat/ACSN4.htm
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 8:24pm
Sounds like you need to work on that serial number a little more.....try a stiff wire brush and some lacquer thinner or BrakeKleen.  Gotta get that old paint out of the impression in order to read it..
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 9:43pm
Does it have a curved gear shift?  Is there a plate on the right side of the engine from front to back?  What are you basing that it's a 45 on?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gramps tractor Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 9:22pm
It does have a curved shifter and it doesnt have the plate. New to here and someone said there may be the number in a different place. I did get the number I listed off the rear left side. Thanks to you all, I'll get my wire brush out again and work on that
. I do have some books for attachments by allis if any one is interested. Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 10:41pm
put a few pictures of it on here
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 9:03am
Where in Michigan? Maybe I could help you look.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 5:28pm
Is this where you got your number from?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gramps tractor Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 7:53pm
yes that is where I got the numbers
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 8:09pm
Numbers are pretty faint. Hope someone has not sanded them off.  I had a pic of mine on here but can’t remember what post it was with. You should be able to find a WD and then six digits.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 8:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 8:23pm
There you go. That is 175421. You have to look hard and have a good light. Get a magnifying glass or your grandkids to have look. If you want to use sandpaper stick to 320 or 400 grit or you will have no serial!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 7:11am
Any luck on your serial number? Maybe a “1” in front of the six?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gramps tractor Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 10:45am
No luck yet,cleaned the area with a brass wire wheel and the wd63 36 show up real well. Im going to figure out how to post a picture but I don't think it will help. The numbers and letters are very vivid. I appreciate you asking though. Thanks a lot!
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 12:43pm
I just looked out of curiosity.  The Serial Numbers for the 45 were:
Year                   Beginning number
1953                          146607
1954                          160386
1955                          190993
1956                          217992
1957                          230295
Ending Serial Number   230298
If your S/N starts with 6 then it ain't a 45.  It could be a 49, 50 or 51 WD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gramps tractor Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2021 at 9:49pm
I just received the operating instructions and repair parts illustrations manual for the model wd tractor. the example of where the serial number is located and has a example of the number being wd-4004  Being only 4 numbers, does this make any sense?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gramps tractor Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2021 at 9:50pm
John I also live in se mi. Blissfield
Post Options Post Options   Thanks (0) Thanks(0)   Quote gramps tractor Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2021 at 9:54pm
Has anyone tried the electrolysis method to remove rust from the gas tank?
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2021 at 6:28am
IIRC, Sugarmaker has several posts on the subject
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2021 at 7:13am
The "WD" series officially began at serial number  7.   The first 6 tractors were prototypes. When they got to 127,007 they changed the transmission gears/shafts and used a curved gearshift lever. This new constant mesh, helical gear transmission was used in WD's from 127,007 on and all WD-45's from 146,607 to the end. So, if the serial number on the rear end housing is lower than 127,007  it will have a straight gearshift in it with a screw on knob. The only way it could have a curved shift lever is if someone used a torch and bent it, because a legit WD-series curved shift lever CANNOT work in the old transmission.  It doesn't fit. It also has a rubber knob that slips on the end, not a screw on knob.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2021 at 7:37am
The 'Operators Inst. and Parts Illust.' for WD-45 is basically a revision to the WD Manual.
You will notice that a lot of the pictures are the Original WD.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote gramps tractor Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2021 at 8:05am
I posted earlier it had a curved shifter and I apologize for that. It is straight. The knob is broke off in half. I can see the very top of the shifter but not sure if it is threaded. The knob is not rubber almost seems like a hard plastic. Thank you all!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2021 at 9:04am
Supposedly one of my wife's ancestor was the founder of Blissfield, MI.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2021 at 1:58pm
Looks like you may have an early WD.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2021 at 3:37pm
   Terry
Watch this Video and compare your Gramps Tractor to those in the Video.
G
https://www.youtube.com/watch?v=MaOe2M-mawQ
Post Options Post Options   Thanks (0) Thanks(0)   Quote gramps tractor Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 8:14am
Thanks for the replies! I have watched the video,and it doesn't have the plate. Would this number be earlier then a 1953?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 8:20am
ALL WD engines had a side plate on the right side of the engine block. ALL WD-45's did NOT. Now, if yours is a WD chassis, it either had a new block (WD45 block) installed one time or a complete WD45 engine.  There was a time in the past where you could not buy a WC/WD block (discontinued) and could only replace it with a WD45 block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gramps tractor Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 9:00am
Was their a difference in the wd and wd45 chassis?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gramps tractor Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 9:02am
Are you saying the earlier serial numbers were wd not wd45? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 9:06am
Yes.
