Shed reno #2 |
fleeter allis fan
Joined: 05 Apr 2018 Location: Niagara Ont Points: 135 |
Topic: Shed reno #2Posted: 14 Mar 2021 at 1:09pm |
Hi All, As I said in an earlier post, when I came to my property in 2005, things were pretty badly run down. This included an equipment shed that I have since restored. It is about 30' X 34' and is post and beam construction. It is probably 100+ years old. As you can see, the roofing and the siding and the doors were in bad shape. There was not really much of a foundation under it and it had sunk and shifted and was way out of square and level.
I jacked it up and tried to level it and square it up and formed and poured footings and foundation all around it. I put a new steel roof on it. I stripped all of the old siding and redid it with 1" X 12" rough milled pine planks. I installed new doors and windows and covered the dirt floor with several inches of granular A gravel. I built a loft with 6" X 6" X 16' hemlock beams and 1" hemlock planks and built stairs to access the loft. It turned out pretty good and should stand for a few more years. I use it to store tractors and implements and other equipment. The loft if full of 'treasures'.
I'm a man...and I can change...if I have to... I guess.
'44 B, '46 WF, '49 G, 810GT, 916H, 620 |
FloydKS
Joined: 12 Sep 2009 Location: S E Kansas Points: 8463 |
Posted: 14 Mar 2021 at 4:19pm |
I would say you done real good.... a little work but the final looks worth it.
Joined: 11 Sep 2009 Location: illinois Points: 89171 |
Posted: 14 Mar 2021 at 5:08pm |
Very nice.... should show a photo of the beam work inside.... NICE to save an old barn !!
Kenny L.
Posted: 14 Mar 2021 at 6:23pm |
Yes like Steve said need pictures of the inside work also, the outside does look good.
Strokendiesel002
Posted: 17 Mar 2021 at 12:16am |
Looks nice, but like the others... Pics of the inside!
Nice job :) |
shameless dude
Posted: 17 Mar 2021 at 12:21am |
you did a great job! it looks really nice!
