Wobble
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Topic: Wobble
    Posted: 04 Mar 2021 at 2:02pm
A friend of mine has a 8N ford and after about 8-10 mph the front wheels go into a death wobble, any ideas on how that can be fixed.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2021 at 2:06pm
Where does the wobble start at steering box or tie rod ends
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2021 at 2:42pm
Tie rods are solid, I think it starts inside the gear box
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2021 at 4:56pm
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2021 at 6:51pm
Steve has probably got the info on it.
Back in my day as a youngster, when you wore the box out that far you put your two feet up on the steering shafts and let her rip.  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2021 at 8:37pm
Hadda MF turf 20, like that, it would do 30-35 mph, with the road gears it had in it.  Wobble started in the upper range!  Maybe its time fer the universal ford fix!LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2021 at 12:57pm
I've always heard the way to fix a Ford (no matter what the problem) was to first find an abandoned quarry. Then tie the steering wheel of said Ford pointed in the direction of the abandoned quarry. Then after starting the Ford (if it will run, if not, push it), put it in gear and bail off LOLBig smileClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2021 at 11:36pm
X2 with Paul!
