Windshield Washer Solvent ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Windshield Washer Solvent ??
    Posted: 09 Feb 2021 at 4:57pm
I've currently got the "blue -10" solvent in my tank that hasn't been "topped off" since I've owned the truck, 5 years. Today I attempted to spray the windshield due to road spray and NOTHING came out (the coldest we've seen is 0) so I assume things are "slushy" and not spraying Cry. The tank is over half full so I ruled that out, but now wondering how to thaw it out without finding a heated garage/shop. Any of you guys gone through this predicament ?? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 5:06pm
Alcohol based, if not used for five years alcohol has evaporated away and you have Blue Water, worthless.  Drain and Refill.  I drain mine by Fall, refill with new and drain again by fall next year.   Good UP TO One Season.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 5:12pm
Thanks DMiller, does the orange or purple colored (for 3 times the $$) hold up better ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 5:14pm
No
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 5:20pm
Use it or lose it. 😳
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 10:53am
With using only 1/2 the tank in 5 years, my guess is pump is dry and gummed up or the lines are. Not that cold is not also part of your problem, but most mechanical things work better being used rather than sitting for months at a time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 11:06am
That would be a logical determination.  My Ford p/u is a part time use, I drain the wash tank on it twice per year as not used much and refill with minor amounts and use the wash when first get in it after days to weeks of sitting.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 12:05pm
I use the RainX orange (winter/summer) washer fluid. I don't think it lasts any longer, but I seldom use wipers when driving at highway speeds in the rain.
I just ordered a new truck and I told my wife I am going to take a gallon of RainX in, so they don't fill it with the blue fluid.
I think you will like it if you try it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 5:30pm
Thanks for the reply Ray, but I've used it intermittently through out the years and as recently as a week ago before the "chilly" temps hit Wink. The evap of alcohol makes alot of sense to me. Thank you all that replied and stay warm this coming weekend Smile !!
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 9:56pm
Can't you just add some alcohol to the old stuff you got and make it usable again!  I got vodka in the garage that ain't froze yet!LOL
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2021 at 6:24am
Check to make sure the spray nozzles are not plugged.
Before moving to Midland TX years ago, I used Prestone washer fluid in the wintertime, not cheap, but worked darn good.
This page was generated in 0.122 seconds.
