D19 D Headbolts? |
Dave in il
Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
Topic: D19 D Headbolts?Posted: 18 Jan 2011 at 12:26am |
Does anyone know if ARP or some other source has head bolts for the D19 D? Part # would be appreciated.
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 18 Jan 2011 at 12:29am |
ARP can supply them, but you have to know the size and length of the bolts.
Bob(FL)
Joined: 13 Sep 2009 Location: Cape Coral, FL. Points: 1323 |
Posted: 18 Jan 2011 at 8:34am |
this is what someone sent me when he did the head bolts on his d19 diesel, got them from arp.
Qty Part number Description 16 AR6.500-1LB STUD ½ X6.5 LONG BROACHED 2 AR7.000-1LB STUD 1/2X7.0 LONG BROACHED 2 AR8.000-1LB STUD 1/2X8.0 LONG BROACHED 20 ARN34 1/2X20 HEX NUT HEAD 20 ARW78N ½ ID 7/8 OD H&M WASHER TOTAL COST IS 169.81 PLUS TAX AND FREIGHT AUTOMOTIVE RACING PRODUCTS 1-800-826-3045 |
nowaktj
Joined: 13 Dec 2009 Location: Elk River, MN Points: 735 |
Posted: 18 Jan 2011 at 4:44pm |
I'm looking to buy mine from Cat. These would be Grade 8 bolts and hardened washers Here are the numbers and qtys I came up with: (10) 7x0331 (4.25" long) (8) 7x0335 (5.25" long) (2) 7x3190 (6.75" long) (20) 5P1076 WashersI think these can all be had for less than $50. What does it mean on the ARP ones that they are "broached"?
Thanks,
Terry
skipwelte
Joined: 29 Oct 2009 Location: Anthon, Iowa Points: 723 |
Posted: 18 Jan 2011 at 4:49pm |
Look at the recommended torque spec for a grade 8 bolt. If I remember correctly the D19 head bolt torque is real close to the yeild torque of a grade 8. I used grade 8s on my D19 D and wasnt real happy with them. HTH
nowaktj
Posted: 18 Jan 2011 at 6:48pm |
Wow...you are right. Cat's normal recommended torque on 1/2 in bolts is 77 ft lbs and their special high torque is 100 ft-lbs. Hmmmm...I am going to have to return these bolts. The Allis spec is 120 ft-lbs.
The practice at Cat is not to lubricate these threads. Is that how you guys do it?
Thanks
Terry
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4573 |
Posted: 18 Jan 2011 at 7:41pm |
My neighbour used ARP head bolts in his D-19D at my insistance. Took ARP three times to get it right. I'm sure an ARP is more than twice as strong as a Grade 8
D-17_Dave
Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
Posted: 18 Jan 2011 at 9:27pm |
I recall someone saying they recomended replacing the head bolts with studs. Might be food for thought as it got ride of the thread problems in the block.
Dave in il
Posted: 18 Jan 2011 at 10:17pm |
Thanks guys. Has anyone bought or priced them through AGCO lately? Last time I did it was over $200 and that was several years ago. I guess I should have ponied up back then and I might not have a blown head gasket today. LOL
Brian Jasper co. Ia
Posted: 19 Jan 2011 at 12:57am |
I just talked to Bill at Sandy Lake and OEM bolts are $25 ea. He said he knew of a customer that had just used ordinary grade 8 bolts but never heard either way how it turned out. Then we talked about the metalurgy involved and the possibility of streching under heat. If anybody was watching Power Block on Spike TV last weekend they were demonstrating the clamping force with a stress gauge and the effects of various lubes available. Motor oil to moly lube to "peanut butter" that Top Fueler's use on engines that make one run and get torn down. It was interesting that the "peanut butter" (not the kind you put on your sandwich) allowed maximum clamping force with one tightening cycle. Repeated torquing allowed enough strain on the ARP stud they were using to strip the threads before reaching specified torque.
Bob, thanks for posting the ARP numbers. I'm going to call them in the morning and get a set for my 262. I was expecting them to be much higher. A set of studs for a 6.0L Ford was over $500 a couple years ago.
Brian Jasper co. Ia
Posted: 19 Jan 2011 at 1:24pm |
I ordered the numbers in Bob's list. Looks like the price has jumped a little. It cost about $208 + shipping. Still less than half of AGCO replacements and probably superior quality to boot.
ac45
Posted: 19 Jan 2011 at 1:41pm |
id go with studs i think, Imnot an ac mechanic, but on most high performance engines where head gasket sealing is maxed out studs are used, sounds like it would fit right in with the buda diesel head sealing issues, It looks like Allis's high torque spec was a band aid for sealing issues
KY
Posted: 19 Jan 2011 at 3:18pm |
I would not use a grade 8. Use the correct bolts.
Brian Jasper co. Ia
Posted: 19 Jan 2011 at 3:56pm |
That test they did and the big difference in clamping force with the same torque setting makes using the special lube ARP has mandatory as far as I'm concerned.
Dave in il
Posted: 19 Jan 2011 at 4:42pm |
Grade 8 bolts aren't good enough, the originals are harder than that and by the second time the head was off they were stretched and should have been replaced.
LeonR2013
Posted: 02 Feb 2021 at 3:52pm |
What about grade 12? Leon
Chad (MN)
Joined: 29 Oct 2009 Location: sc minnesota Points: 288 |
Posted: 02 Feb 2021 at 4:08pm |
Pfouts sell the ARP stud kit for the D17-D19 diesels
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
Thanks(2)
Posted: 02 Feb 2021 at 5:06pm |
You guys can use Grade 100 bolts and it'll still blow a head gasket if the sleeves are sunk below flush on the deck.
jeickman01
Posted: 03 Feb 2021 at 4:40pm |
Didn't the D19 have a well known problem with the liners sinking in the block? Worked for the green outfit as a service rep. Checking liner protrusion was part of every head off repair even if it wasn't for a head gasket failure.
Thanks(1)
Posted: 03 Feb 2021 at 5:46pm |
YES. Terrible problem on the deezels and the gassers (same sleeves/block) never bothered.
