FP 60 Forklift
Howard the duck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Howard the duck Quote  Post ReplyReply Direct Link To This Post Topic: FP 60 Forklift
    Posted: 26 Jan 2021 at 1:43am
Need help with the kind of engine in FP 60 forklift
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 5:37am
hmm. I'm guessing it'll be a 6 cylinder, either gas or diesel. At 6000#,probably not propane. If you have the 'tag info', that'll help, as well as fuel(gas,diesel,propane).
www.liberatedmanuals.com ; has 100s of AC forklift manuals for free, yours is hopefully there(sniff..I couldn't find mine ,FPD50-24-2PS,sigh...)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Howard the duck Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 6:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 6:53am
found these...
there's a few more on the site...
good news it's a gas engine ! maybe a G-226 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Howard the duck Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 7:15am
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 10:01am
Engine will be A-C (Buda) G-230
Post Options Post Options   Thanks (0) Thanks(0)   Quote Howard the duck Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 5:51pm
Thank you Calvin! Do you know where I can get parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 7:15pm
What do you need ? AGCO farm dealer might be able to help. Same engine as a Gleaner A combine. Parts are getting hard to get. Depends on what you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 7:30pm
Really Calvin.. SAME engine ? I KNOW where there's a sweet 'A' sittin. So do you ! I gave it to Ron as a birthday present 3 years ago ....or 4 ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 8:12pm
Jay, maybe Ron would be happy to give it back!  The bigger forklifts that have the 6 cylinder engine , the engines are a 230 and are the same as a Gleaner A. Governor will be different. A 262 from a Gleaner C or CII or D19 is externally the same as a 230. The 4 and 5000 lbs forklifts have the four cylinder version of the 230 which is a 153. A 153 is not used in any A-C farm equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 9:04pm
I'd lik eit but sold the acre I used it on, sniff, sniff. My 5K lift has the 4BD153 in it that now has new front tires.be interesting to see how they like that white stuff we got today ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Howard the duck Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 10:11pm
Water pump radiator hoses fan belt little stuff like that.
KristPom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KristPom Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2021 at 4:55am
Hi! To select an engine, you must first determine the operating conditions. For example, choosing a forklift truck with a diesel engine used to transport goods over short distances (for example, on the territory of the plant), it has all the necessary qualities. Gasoline-powered forklifts for work not only outdoors, but also inside — in warehouses, factories — a more "quiet" loader with no less power is needed. Electric motor forklifts are used if you plan to use loaders mainly indoors, then the electric motor option is perfect for your work. They helped me pick up a good forklift truck on https://anguslifttrucks.co.uk/forklift-hire-uk / and you can also turn to them.
Edited by KristPom - 05 Nov 2021 at 10:33am
