AC 200 hard starting
rodnil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rodnil Quote  Post ReplyReply Direct Link To This Post Topic: AC 200 hard starting
    Posted: 26 Jan 2021 at 8:06pm
I know it is winter and low temps make them start hard. But my 200 is hard starting in warm temps. I have new cables from Agco and two new high  capacity batteries and even with jumper cables from my truck it requires several shots of either and several tries to get it fire off. Any ideas or thoughts ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 8:19pm
Any smoke coming out of the exhaust as you crank it?  If so, what color?
Could be low compression, could be a fuel delivery issue.  Have the air filter and fuel filter been replaced recently?  How is fuel flow to the pump?
In the winter time (or below 40 degrees) DEFINITELY plug it in or use the manifold heater!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rodnil Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 8:26pm
No smoke. All filters were changed late summer. No block heater , why ?, I don't know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 8:35pm
No smoke while cranking indicates no fuel getting into the cylinders.  Pump might be getting weak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 8:55pm
My XT did the same thing. After checking fuel flow to the filter, then to the pump, off it went to Ed where he did a rebuild. Starts and runs great now.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 9:00pm
How fast does it spin engine ? Could be bad starter plus inj. pump needs rebuilt and timing restarted.                MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote rodnil Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 9:07pm
Mack; not a fast spin. It's like having low charged batteries.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 9:21pm
It takes about 800 RPMs to build enough heat to fire diesel.          MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2021 at 6:21am
My first guess is you have a Lucas brand starter and it is performing at half-speed. Not saying this is the whole problem, but the engine has to spin at least 200 RPM steady for the injection pump to even deliver fuel.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2021 at 7:22am
Like said above, it is cranking super slow, so my first move would be starter, I think the gear reduction for a 6080 fits and is readily available? Make it crank fast first, then worry about if it needs pump work, which it still might.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2021 at 1:34pm
Nothing like a fresh pump job (+ injectors)
CDN 400 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDN 400 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2021 at 4:54pm
Especially when Ed does it Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote rodnil Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2021 at 9:09pm
Thanks for the info guys. I'll start with the starter . If that's not the answer I'll send the injector pump to Ed. He rebuilt my injector on my 220. Will not be able to work on it tomorrow as I'm off to Weatherford, Tx tomorrow early AM. I'll be hauling a new Ford 450 pickup to a new customer . Be back in 3 days if all goes well and I'll get to work on the tractor then.
