7060 alternator problem
ToddnwIl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Topic: 7060 alternator problem
    Posted: 13 Jan 2021 at 4:39pm
Our 7060 had the neihoff alternator on it and we have changed it over to a delco 110 amp alternator. We are using the old pulley but the tachometer isnt reading right. What pulley do we need and where can we get it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2021 at 4:53pm
betcha Steve wil know........
I'm thinking if it reads low now, you need a smaller pulley as that'd speedup the alternator.
Course that begs the question HOW will you know that 1200 RPM IS 1200 RPM ?
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2021 at 5:02pm
If you are using the old pulley, I should be turning the same speed. There may be a difference in the number of pulses between the alternators.
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2021 at 7:09pm
I believe ( can't remember for sure, someone told me that when I was thinking of a Delco.) you need a pully from a 1206 int. and that should make your tack accurate
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2021 at 7:39pm
Size doesn't matter.   haha
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2021 at 8:08pm
I get mine from Sioux City.  They are 3 7/8 outside diameter. I was thinking that Shoup offered them too??
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2021 at 8:56pm
I can help with the correct pulley for the conversion and also the belt will line up better.
Albert
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2021 at 10:10pm
How did ya get the niehoff pulley on the Delco? The niehoff I have seen, the shaft is smaller than the Delco, I suppose it could be drilled....
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2021 at 10:16am
I was wondering the same how you got the pulley to work.  A year or so ago I changed out my 8030 to a delco and had to get a new pulley as the one it came with only had a single grove belt set up and the niehoff pulley would not work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2021 at 11:56am
40+ years ago, A-C had a "kit" to update older Delcrotron alternators (old maroon 7000 series) to the new 100 Amp Neihoff. It came with a new tachometer. Must be the old tach wouldn't read correctly with the Neihoff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2021 at 9:53am
Not only did some of the Niehoff's have a smaller .580 shaft, vs the .670 Delco shafts, the pulley diameter as well as the offset was a bit different also if memory serves me right. As Albert mentioned the belt fits better. Its been quite a while since I've changed over a Niehoff. They were a PIA sometimes when it came to tachometer outputs...
Steve@B&B
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2021 at 10:17am
I use Select Parts # 778-1069-1 it is the right to change from Niehoff to delco tack will work right niehoff pulley was 3 1/2 O.D  delco is 3 7/8 O>D.O Shaft size is.670 For both
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2021 at 10:32am
Hy Capacity has a pulley for this conversion.
