B Cylinder pressures |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: B Cylinder pressuresPosted: 31 Oct 2010 at 12:20pm |
What is the standard pressure test values?
Engine has good power and doesn't smoke except for a slight puff at startup. I'm looking at some down time and was looking for things to do and working on the B is therapeutic. Thought about checking the bores getting the head checked. Might need my head checked since it runs good as is. |
Charlie
Jeff Z. NY
Posted: 31 Oct 2010 at 12:29pm |
If you get 125 you are doing good.
A slight puff of blue smoke at start-up sometimes is just some oil coming down the valve guides. To do a good test get the engine hot. Remove all spark plugs. Gas shut off. I shut off the gas and let the engine drain the carb and stall before the test. Choke and throttle wide open. Air cleaner unhooked. Give each cylinders around 6 revs for the test. |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42131 |
Posted: 31 Oct 2010 at 12:30pm |
pressure isn't the important thing it isthe variation between cylinders that is . You can have loss of compression across all cylinders showing normal wear but when a large difference shows between them , problem needs to be found.
Edited by Coke-in-MN - 31 Oct 2010 at 12:58pm |
Jeff Z. NY
Posted: 31 Oct 2010 at 12:50pm |
Right, If you have 10-15 lbs differance between any cylinders it is time.
Charlie175
Posted: 31 Oct 2010 at 3:50pm |
I split the tractor today to replace the throwout bearing only to find I was shipped a D12 bearing, the B is much smaller! Time to re-order.
I also removed the radiator as I had a slight drip from the upper neck, looks like the weld cracked. Need to find a local repair shop to have them fix it. Cold I got 90 psi on 3 and 89 on 1. All the plugs look normal so no oil burning. My pressure gauge must be off as on my motorcycle it reads lower than normal also. I also noticed the governor rod was hitting the belt drive and it had rub marks on it so I tweaked the rod a little to get it to clear. Now the carb goes from stop to stop with no interference. Maybe I will get full power now :) not that I thought it was lacking before. I like the simple nature of this tractor! |
Charlie
Jeff Z. NY
Posted: 31 Oct 2010 at 4:12pm |
They look ok. 90 is low but if you do it again with a hot engine you will see better reading.
Cold tests are always wrong. The good thing is they are all equal. Anything below 90 I would fix. |
JimD
Joined: 11 Sep 2009 Location: Mounds, OK Points: 2116 |
Posted: 31 Oct 2010 at 8:33pm |
That is a little low on compression. Not real bad, but wil make it a little harder to start and have a loss in power. Put some oil in the cylinders, and see if the pressure numbers come up. If so, the rings/pistons/cylinders are the problem. If not, the valves are suspect.
JimD
CTuckerNWIL
Posted: 31 Oct 2010 at 8:42pm |
Maybe you should have your head examined. LOL Now you done it Charlie. Ya got me thinkin I should check my B. Well it might not get done this year cause it's in the neighbors shed a mile away and the coolant has been drained.
Charlie175
Posted: 31 Oct 2010 at 9:08pm |
it fires right up now, I can't imagine it being easier to start.
I'll check the valve settings as I'm sure they haven't been touched in years. |
Charlie
CTuckerNWIL
Posted: 31 Oct 2010 at 9:21pm |
Mine too. Almost always on the second quarter turn of the crank, unless I forget to flip the kill switch to the run position.
Charlie175
Posted: 01 Nov 2010 at 6:15am |
How worn do you let the fingers on the pressure plate get worn down?
Oh and the bearing was toast but the clutch pack looks good.
Charlie
Coke-in-MN
Posted: 01 Nov 2010 at 7:19am |
10% variation is one sign of problems coming. Another way of checking is to use air into cylinder through spark plug hole , listen for air at carb for valve problems, breather for blow-by problems.
tractorkid1
Posted: 01 Nov 2010 at 8:29am |
I always liked using the cylinder leak down method insted of a compression gauge reading. The leak down test tells you more information as long as youlook and listen to where the air is coming out.
Charlie175
Posted: 01 Nov 2010 at 7:20pm |
Kudos to Scholtens Equip.
I emailed them today about the bearing and they are overnighting me a replacement free of charge! Great service. Now I have a 2.5" ID x 4" OD throw-out bearing if anyone knows what it goes to and can use it.
Charlie
