Rear inner weight question
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: Rear inner weight question
    Posted: 17 Dec 2020 at 6:24pm
How much could inner weights for 38 inch castings weigh?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 6:30pm
Ive  heard 1400 lbs,,, those are monsters, sorry thought they were the big dudes,, pictures were hard to tell,
Edited by DougG - 17 Dec 2020 at 7:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 6:47pm
mine are only 2in? thick...seen a lot thicker ones....don't know how many variations there are
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 7:12pm
I think these are 2 maybe 3 inches thick, and 31 inches wide
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 7:13pm
My 7060 and 8050 have 2 on the inside
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 7:20pm
cast weighs about .284#/cu in or 491#/cu ft
so...
figure out the volume of the weight..
measure then subtract 'hole' from total..
 all I know is my back hurts just LOOKING at them !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 7:26pm
400 lbs each.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 7:30pm
Thanks Dr
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 9:24pm
What was the usual installation for these inner rear wheel weights? Factory installed? Dealership installed? Field (on farm) installed?
If weights were not factory installed onto tractor, how did truckers usually secure them to their trailer for transport from factory to dealership ? Metal crate? Wooden crate? Etc...??
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 10:54pm
You say 31" wide which I assume to mean diameter?? Would these same weights have been used on a 34" wheel too?? Our 1966 190XT has 1 inside each rear wheel with the 6 pie weights on the outside of each wheel too. We are the 2nd owners and bought it as is in 1970. Local dealer sold it brand new and Dad knew the original owner. Tractor was ordered that way due to the very hilly fields that were on the guy's farm. He wanted it heavy to pull/hold on his hills.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2020 at 9:00am
I think that is the same weight I had on my D21, had three on each side, when I traded for 7030 the dealer took them off and put 2 on each side of that.  Dr knows but my dealer called them 450 lbs.
This page was generated in 0.263 seconds.
