Above ground TORNADO shelter |
Page 12> |
Clay
Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10390 |
Topic: Above ground TORNADO shelterPosted: 09 Dec 2020 at 11:16am |
Need to build an above ground concrete tornado shelter.
The interior needs to have a 6'5" minimum ceiling height. Door width of at least 32". Oz SafeRooms has an excellent shelter but the price is beyond the budget. Considering building it myself. I have the skill sets to accomplish the task. Need a blueprint and materials list before I budget for the project. Most of the pre-fab shelters have problems. None of the in ground pre-fab are satisfactory. |
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 09 Dec 2020 at 11:54am |
I would make it round, like a concrete silo but only as tall as needed.
I saw a home that a guy made from a round steel grain bin. Dusty
JohnColo
Joined: 03 Apr 2020 Location: Niwot, CO Points: 1263 |
Posted: 09 Dec 2020 at 12:31pm |
What about getting a 2000 gallon or larger concrete septic tank made with a doorway in it. Set it upside down on a slab and cover most of it with dirt? Might even put an entrance way a few feet long with a roof over it to protect the door. I'm glad I live in a place where tornado's are rare!
Joined: 11 Sep 2009 Location: illinois Points: 90645 |
Posted: 09 Dec 2020 at 12:47pm |
How about laying up blocks... then filling the inside cavity with concrete , maybe even a stick of rebar.. You can make any design you want.. ROUND seems like a good idea.
Dont know what they use for a roof, but you can setup braces or scaffold inside, put a sheet of plywood on that, and pour a 4 inch concrete cap that has rebar and ties into the walls..... after a couple weeks, take down the scaffold and pull off the plywood.
Posted: 09 Dec 2020 at 12:54pm |
How about a CONEX box or SEACAN ? They are steel on 6 sides.. A small one is 20 ft long and 8 ft wide... Maybe they have even small of some sort... Set it on the ground and push dirt up 4-5 ft on the 3 walls to help stabalize.. You can cut into the steel for a vent, etc.. Big doors on one end.. Bolt one shut and modify inside/ outside latch for the other ??
Edited by steve(ill) - 09 Dec 2020 at 1:00pm |
nella(Pa)
Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3145 |
Posted: 09 Dec 2020 at 1:04pm |
Next thing you know someone will suggest a fridge with a keg inside of it!
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11388 |
Posted: 09 Dec 2020 at 2:20pm |
I think one of them containers could be made into a nice shelter a lot cheaper than biulding one.
festus51
Joined: 26 Mar 2017 Location: Osage City, KS Points: 1644 |
Posted: 09 Dec 2020 at 5:10pm |
Just to be different, I would build it out of poured concrete and anchor it with rebar a foot or two of concrete floor in the ground and pushing dirt up on three sides is very good idea. Been through a couple of tornados here .
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35599 |
Posted: 09 Dec 2020 at 6:13pm |
Conex boxes do not do well buried, Sides cave in as not designed for Side loads just Edge loads. Know of two purchased and set onto Concrete slab with footer, then forms and rebar added around with support braces INSIDE at two foot intervals concrete poured and allow to cure before removed bracing. When poured Cover Top laid Styrofoam on the top and sealed edges, forms set to side walls, bracing installed top to bottom and pour completed.
Should be able to park a tank on top now.
Posted: 09 Dec 2020 at 6:33pm |
I would not BURY the Conex.. Would set on gravel with good drainage, then push dirt up maybe 5 ft on the sides. Rain would run down the slope and away from the conex. Dirt would help "anchor" to the ground so could not "move" in a tornado. Steel sides should be adequate for 5 ft dirt height... Might want to tar the outer walls for rust prevention...Leave access door on the end.. Might be a good idea to have a door on each end in case one gets blocked / damaged in storm
john(MI)
Posted: 09 Dec 2020 at 9:56pm |
Go here. if you want call first and ask to speak with the ESA or an ET. Ask the person if they still have the blue prints for the office. The file/copy room is an above ground concrete vault with a special door. This is the tornado shelter. The prints should give you some help designing yours. If they ask, or you wish to, tell them that a retired ESA from DTX, the Detroit office, referred you. They are a little skittish with the way of the world so if you throw around some additional contacts it will calm them. Those are abbreviations not words, You say the letters e.s.a. or e.t. The m.i.c. is the boss of the building so you might need to get his permission. If you have problems, let me know and I'll go into the office here and get what I can from the prints. Actually, with the covid, they may not let you or me in. National Weather Service E Witchita Ave, Colwich, Kansas, 67030 316-942-3102 I think the walls are only about 6" thick from what I remember at the door frame. There is a poured concrete roof on top. I'm not sure how deep it is anchored, but I know the floor is at least 4" thick. I'm sure it had a complete cage of rebar in every surface. The door is steel with 4 bolts that engage in the frame when the handle is turned. We had phone, electric and internet available inside. It is probably 8 x 12 if I remember correctly. I believe they figured it for 16 people. I can try to get more info if you want.
festus51
Posted: 09 Dec 2020 at 11:08pm |
John now that is what I was talking about. 300 MPH winds you want some substantial concrete around you.
modirt
Joined: 18 Jul 2018 Location: Missouri Points: 9391 |
Posted: 10 Dec 2020 at 8:17am |
Granted, I don't know a whole lot about tornado shelters, as every house I've lived in (except one I have now) had a basement. Plan was always to go to SW corner of basement, huddle against the wall and watch the house disappear above you. But on these tornado shelters, I did see a news program once that featured the Texas Tech storm shelter research / testing program....and that was kinda scary. They would test fire a 2 x 4 at a wall at 200 mph. Kinda scary how many went right through the wall. So takeaway was these things, to be effective, are highly engineered to withstand flying debris as much as to sit in place. If I was gonna buy or build one, I'd want a design that was up to snuff. Otherwise, just a false sense of security that might wind up being a death trap.
Posted: 10 Dec 2020 at 2:42pm |
The only problem with concrete wall is you need to have a CONTRACTOR setup and pour.. There are reinforced FRAMES that you setup to pour the concrete into... No forms, your out of business..... and your not going to stick a couple sheets of plywood and a 2 x 4 on each side and expect to pour a wall 8 ft high.. You will spend more on FORMS than the concrete.
HD6GTOM
Posted: 10 Dec 2020 at 3:42pm |
There are fellows around here that used to build cement dome houses. I was in one west of Lacona Iowa years ago. They look like 5 or 6 coffee cups turned upside down joined together by doorways. These domes were about 12' across at BBC the bottom. One of these would make a great storm shelter. I think they were called geodesic dome homes.
Dakota Dave
Posted: 10 Dec 2020 at 6:16pm |
You can go to fema.gov and down load the storm shelter hand book. It has specfications and plans for designing your own shelter. The last section is drawing of construction details for building wLss doors vent systems and anchoring.
Adam Stratton
Posted: 10 Dec 2020 at 8:22pm |
Havent really had to test it but we buried a conex container. I had a deep ditch not far out the back door, so I dug one side out enough to sit it in. Put rock and drainage tile around it, put a culvert along the ditch side, covered the whole thing with roofing tar and a layer of tyvek and made a doorway. Then pushed dirt over the whole thing. 10 years ago or so and still holding up fine.
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13766 |
Posted: 10 Dec 2020 at 8:28pm |
I remember back in the 60's 70's,,,,several of the farmers around here built half underground and half above ground "shelters with an igloo type entrance. The mounds was covered with dirt then seeded with grass which they kept cut down during the summer. I went inside one and seems like the walls were cinder block with lots of shelves for storing foodstuffs. My Dad started contracting to DIG holes in back yards to be used for fallout Shelters right after the Cuban Missle Chrisis,,,,and me and my older brother were the backhoes, because the owners did not want their back fence torn down . I learned pretty darned QUICK that if you don't learn how to pitch a shovel full of dirt up bout 6 foot high,,,,,you gonna have to pitch that same dirt back up outa the hole all over again and,,,and,,,maybe two,three more times,,,!!!!
I think we dug bout 8 holes for shelters and is why I HATE shovels now,,,,![]() |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42259 |
Posted: 10 Dec 2020 at 8:56pm |
Might look up a video they had on This Old House - PBS - as they had a show on then and building them . One was free standing on a cleared lot - said house was gone, as much of neighborhood was now rebuilt but this structure was still standing and family was safe because of the shelter .
Showed a crew building one inside a garage area , all poured concrete with rebar skeleton , vibrated concrete during pour and roof or top closure was rodded to sidewalls over a poured form . So full unit was poured over large plywood box form but also onto foundation that was designed to not yield in a direct hit . |
shameless dude
Posted: 10 Dec 2020 at 9:29pm |
lots of info on the web about concrete homes, connex homes, cave homes, and check you tube, lots of info there too! if going to pour an above ground concrete structure, you need deep footings and lots of re-bar, walls should be a minimum of a foot thick, and you need to do it in one continuous pour.
TomC
Joined: 24 Nov 2017 Location: Hillsboro, MO Points: 1549 |
Posted: 10 Dec 2020 at 9:33pm |
Call me crazy, but having been in three different tornadoes in my life, Above ground / tornado shelter don't belong in the same paragraph let alone the same sentence. Not me,it's either the southwest corner of the basement or a regular old storm celler.
Posted: 11 Dec 2020 at 6:19am |
Same Here Tom. Seen Conex Boxes lofted to thirty feet up and tossed like ragdolls in a tornado in OK when lived there. Just because large and heavy does not mean impervious. Sides are not that thick to stop wind born missiles neither the roof. Better off with a Concrete Steel reinforced structure.
Coke-in-MN
Posted: 11 Dec 2020 at 12:38pm |
Mobile home parks (tornado targets) here in MN are required to have storm shelters and they seems to be concrete with earthen berm as easiest and cheapest form of construction to meet code .
Now it seems if your out in rural area a simple means would be a large oval concrete culvert section with enough dimension to be used for other purposes also . This could be sunk down into side hill or just at lower elevation so as to not look like a eyesore in the front yard . |
festus51
Posted: 11 Dec 2020 at 9:04pm |
desertjoe
I remember a similar experience when I was in my teens. Man came out of ST Louis looking for trees to dig up. Stop at our house and dad made a deal with him. Me and brother spent a week digging up small trees. When the guy from St Louis came back he only took about a third of the trees we had dug up . Dad sent him packing with no trees. Me and the brother provided more free labor. But it is a lesson I never forgot.
shameless dude
Posted: 21 Jul 2021 at 8:16pm |
used to be a family here that made concrete grain storage bins, the son made his house out of several of the bins connecting them with arched walkways, his dad made his 2 car garage out of one, had a walk door and a large overhead door. they hunkered down in the garage one evening when a tornado went thru, all walked out just as good as they walked in, everything outside was ripped up! he has since passed and the son sold the farm place they lived on, but the house and the garage are still there and look just like they did when constructed. i was in the garage one day, seems the walls were about 8 inches thick.
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10924 |
Posted: 21 Jul 2021 at 9:55pm |
They have concrete pump trucks, I think that is what they are, that can 3D print a concrete house. Check them out. Tracy
Posted: 22 Jul 2021 at 4:51am |
Precast companies here have been producing septic sized shelters with a hatch style door as the old homes used to have for cellars. Require the boxes be anchored and then earth nested to keep them
In place during a event. |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12412 |
Thanks(1)
Posted: 22 Jul 2021 at 6:44am |
I see we're eating spam for breakfast again.
Posted: 22 Jul 2021 at 8:11am |
BUTT, BUTT, BUTT... you didnt answer felici question.. What about the scaffold ?
sho-man1
Bronze Level Access
Joined: 14 Sep 2009 Location: Wylie, TX Points: 196 |
Posted: 22 Jul 2021 at 8:45am |
There are a few tornado shelter businesses in Joplin, MO.
Here in north Texas it is popular to have an above ground in the house steel room. Home depot sells the round steel ones. Last estimate for semi-submerged concrete clamshell shelter outside my back door was turnkey at 10K. Salesman's jaw dropped when I asked how he slept at night after robbing people for 7K...They pour pre-formed halves at their shop, dig a hole next to your house, flip one half in the ground, pour flexseal on top, then drop the top half on, couple brackets welded together. Did not go for that one....
Page 12> |
