6080 external thrust bearing
McGuire View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGuire Quote  Post ReplyReply Direct Link To This Post Topic: 6080 external thrust bearing
    Posted: 25 Nov 2020 at 1:38pm
Hi everybody! I am new to the forum. I have recently undertaken the task of saving a early model 6080 for a friend. It hasn't been ran in roughly 15 years, it does now. The question I have is with the external thrust bearing. How is it shimmed or adjusted? Are there even replacement parts available? I have all the manuals(operators, service and parts) however, that is not even listed. The pto wont engage at all. The tractor runs and drives and brakes all work. Several weekends of fussing with it. But the bearing in the bra has me perplexed... thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGuire Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 3:37pm
Pics of tractor:
WNYBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WNYBill Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2020 at 8:36am
Can't help you with the bra.  The PTO is an abomination. The 6000 series is a Fiat Tractor with a Allis engine.
Has the tractor been run with the PTO clutch lever pulled back?  That is what puts pressure on the crank bearings.  There is a good possibility that the PTO clutch is "frozen" or just out of adjustment.  It is cable operated.  There is a shaft that goes through the torque tube that may be seized, that is what operates the front clutch, the PTO clutch.  Try lots of penetrating oil and moving it side to side as well as rotating it.  Tractor has a duel clutch, not  a 2 stage clutch.
When everything is working the 6000 series is a handy tractor.  I see yours has a new seat.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2020 at 8:50am
The bra as no bearing on the PTO working. That just affects the crank.
The PTO, you pull back on the big stick. Then to the left of seat you pull up on the lever there to engage the PTO gear. Letting the Big stick forward will engage the PTO (Allowing it to run).
Ensure the left lever is moving the PTO engagement arm. It may be stuck
Charlie
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2020 at 11:28am
For crank end play you have to use a dial indicator, usually set it on the crank pulley and then bar it back and forth to get a measurement of how far it moves.  Do a check first before you take anything apart so you have a baseline measurement.  It is also a very good idea to remove that front plate and check total movement of the crank, especially if the tractor is new to you.  I set mine at normal crank thrust clearance, around .005"(book shows .003 to .013), but check your total movement first just to make sure you set the thrust plate at least equal to that amount or less.  Maybe you have a crank endplay of only .004(very rare) then I would try to set the thrust plate at that.  DO NOT set it at zero or preload, you want normal bearing oil clearance to prevent wear.  You have to add or subtract shims/washers from the front plate to change clearance.  Important that you grease that bearing zerk in there at least every oil change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGuire Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2020 at 5:21pm
Thank you gentlemen! Spent the day reworking the external thrust bearing. They each have a stack of .042 and I can push the crank back an additional .018. Making spacers on the milling machine and lathe to bring it into spec. Broke the pto clutch cable trying to free it up. However if I push back on the crank pulley the pto will engage, its noisy but engages. Go figure. Have to pull the rear pto housing off and fix someone's else's repair. New old housings are ridiculously expensive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGuire Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2020 at 5:26pm
Picked up a slightly used one on ebay. Pricey but worth it. The pto clutch lever was all the way down. However, the pins going to the clutch arm were missing. New ones made on the metal lathe and installed with bronze bushings. Ordered a new clutch cable from amazon.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2020 at 9:11pm
If you have .018 end play, you need to go inside and check condition of crank and block.               MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGuire Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2020 at 6:16am
That's what we were thinking as well Mack. We will drop the pan today to see what's going on in there. Ended up machining. 020 off the stub shaft as it was rubbing on the plate. The pin holding the shaft to the plate was broken. Machined a new pin and put weak spot in it as the original must've had. Still fighting with the rear hydraulic cylinder to get that off. To get the PTO housing off to seal up the leak around the welded repair area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGuire Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2020 at 11:11am
Removed oil pan inspected crank and block. Did not see any damage checked bearings they looked really good for only having 3500 hrs on them. Reinstalled pan. Reinstalled stub shaft on external thrust bearing with one .030 shim on each bolt and a .042 shim on the front of the shaft to make up for the amount I milled off to reface and flatten the surfaces. Total end play now is .006. PTO still problematic in engaging. Thinking clutch fingers made need adjustment? New pto cable should be here in a few days. PTO housing is leaking at weld site. Thinking drain hydraulic oil, clean surface with oven cleaner and apply JB weld? Looking for body panels and new dash cluster. Owner wants tractor to look new at all costs. It's going to be mainly used for bush hogging and to rin a belsaw sawmill.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2020 at 8:19pm
Where are you engaging pto. Sitting in seat. Left side is a knob sticking up next to seat. That's a seasonal disconnect, which the tractor needs to be shut off to pull up into gear with out grinding. Then you let the hand clutch on right side forward to engage pto. And if your not using pto you leave hand clutch forward and leave the knob on left side down, disengaged.
Edited by Mikez - 28 Nov 2020 at 8:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGuire Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2020 at 7:30am
We are using the rod on the left side and leaving the pto clutch lever all the way forward. Shifting it only when the engine is off, guessing it's going to be a job of adjusting the pto clutch inside the trans...
Post Options Post Options   Thanks (0) Thanks(0)   Quote WNYBill Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2020 at 7:51am
Idle the tractor down, pull the right side handle back, pull up rod on left.  If things are adjusted correctly, it should not grind.  Move right lever forward to engage the PTO.   I have the right lever adjusted so it will not lock back, just pull back to stop PTO temporarily.  Right lever forward and left rod down when not actively using PTO.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2020 at 9:51am
This clusterf*** system is exactly why I would never own a 6000 series AC. A hydraulic PTO clutch like my 200 has would have been so simple and reliable. I know they are Fiat built tractors except for the engine and for the most part they are good tractors but the PTO clutch was just poor engineering.
Edited by Ky.Allis - 29 Nov 2020 at 4:48pm
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2020 at 7:16pm
It’s really a no issue we got one with 11,000 hours, another with 9000+, another that reads 6500 but based on condition compared to the one with 11,000 the 6,500 hour one has 16,500 hours.  Ours do a fair amount of PTO work.  I’ll take the fuel efficiency and nimbility of 6000 series.  New York Bill way over plays the long PTO lever.  For YEARS we left the long lever back between fields haying or between loads spreading manure. Even if you do the seasonal disconnect it takes what max 15 seconds?
ssefick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2022 at 9:10pm
Hello, I just bought a 6080, and I need to check the bearing play. I do not know how to do this.
Do you mean a wheel bearing dial indicator? When you say bar it back and forth. Do you mean like use a crow bar?
I do not want to break anything trying to fix fix the tractor.
Thank you for all of the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2022 at 3:19pm
The idea is to pry fore and aft. The pulley is easiest and any bar you come up with to do the job. Without prying pressure and dial indicator you will not know what the true end play is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 1:11pm
Thats quite a fix Allis came up with to hold the crank back- combine engines have no pressure against them so kinda the weakness showed up - must have cost AC a bundle in under warranty $$$$$$$$$
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2022 at 8:06pm
The crankshafts thrust bearing on the 6060-70-80 was/is the same as a 180-185-190-190XT-200-7000. It was plenty for all those models, but when combined with the European designed dual clutch (traction and PTO clutches) it was borderline overloaded. This was especially true when someone has the stage coach handle pulled back and locked and then stepped on the foot clutch to start a cold engine with no oil pressure.
This page was generated in 0.211 seconds.
