Cane picker D17
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Topic: Cane picker D17
    Posted: 22 Nov 2020 at 5:19am
I came across this and thought there may be some interest.  It looks like it's reversed, so I suppose it could be used for various applications.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2020 at 7:58pm
Would like to see it, but all I can get to come up is a bunch of used cars.
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2020 at 8:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2020 at 10:58pm
I didn't look close enough when I first saw it.  Is that a D17 Series IV?
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2020 at 12:33am
Would of liked to bought it. I have a d19 highcrop set up the same way
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2020 at 1:13am
Working now. Why are there wheel weights only on the right side rear wheel?
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2020 at 5:23am
To offset the weight of that boom when it swings with a mouthful of cane
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2020 at 9:20am
Series 4 is correct.
Sherman Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sherman Farms Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 5:10pm
Wish i had seen it sooner, it would go great with my LP and Diesel hi crop series 4s.
B, C, RC, 3 wc,2 wd,3 wd45, d15, d17, d19, d21, 190, 440, 7040, 918 backhoe, 12 roto balers, 7 60 combines, 40, 66,2 72,90 super, sp100, Gleaner E, F3, 3 L2, R62, and much more
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 5:38pm
Looks like a D-19 34 inch rear wheel center with D-17 hoods ??
eighty nine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eighty nine Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 6:56pm
It does look more like a D19 than D17. Torque tube/housing is definetly from a 19.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 7:31pm
Rear is a D 17.
I owned a couple that were built with D series 19 on the front.
Front axle looks like a 17 to me to low for a 19
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 7:47pm
That is a D-19 rear axle with a cast iron wheel center and SIX pie weights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 8:09pm
OK.....This is one of those with the double final drive that drops down low. They obviously used a D-19/190 rear wheel center instead of a D-17 stamped steel center.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 8:58pm
The series 4 d 17 high crops use those centers and rims
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 9:10pm
Picture of a D 19 High crop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2020 at 11:49pm
It is a D17 have six of them. Would like to have bought this one to
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2020 at 8:22am
looks like one I have , mine is a d17 series 4 diesel heavy front end like d19 with 7.50x20  , rear cast are like d19 but have bolt on 8 bolt and double bevel rims with 15.5x38 , final drives are three gear drops , ring gear and diff are on other side to turn gear the right way because of the three gear drops , I do not have any of cane parts just tractor , would sell ,
This page was generated in 0.859 seconds.
