P T O 190xt
KP4620 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KP4620 Quote  Post ReplyReply Direct Link To This Post Topic: P T O 190xt
    Posted: 18 Nov 2020 at 12:43pm
I have a 190XT with a mech pto.  I know it would be much handier if it was hyd.  Is that a bad or expensive job to put a hyd pto on?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 1:31pm
Since you could buy another tractor for what it would cost yes to both questions. Your going to get i did it for only a couple hundered replies they had to get all the not avaliable part X from somewhere and you still have to dissasembled the counsel and to the hyd stack and split the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 1:32pm
A complete PTO clutch box, control valve, PTO lever/linkage from console down to the valve and all the steel lines. All can be done without any major work. No split involved. Nothing available new. Will have to come from a salvage unit. Don't know what a salvage yard might want, but I'm thinking $500 to $700 bucks ???
Edited by DrAllis - 18 Nov 2020 at 1:34pm
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 1:33pm
Change the pto box underneath, and the valve, and lever, linkage in the console and proper hydraulic lines. The box would have to be the same pto speed as you have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KP4620 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 2:14pm
now, Does a 190xt with a hyd pto , is that a live pto or does it still quit when the clutch is depressed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 2:16pm
Foot clutch still kills the PTO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KP4620 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 2:18pm
Won't work very good for bush hogging into corners then ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 2:38pm
The only scenario it helps with is like hauling manure. You pull into the field and engage the spreader on-the-go and can shut it off on-the-go.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 5:00pm
IMO, your better better off with what you've got, even with hydraulic engagement, once the foot clutch is depressed , the pto slows/stops . Other than the PD lever, there's nothing "live" about the pto. Sad that ALLIS couldn't come up with live pto in the 100 series era Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 5:46pm
But, with the hydraulic PTO you can engage and disengage on-the-go under load or not without harm to anything. You cannot do that with the manual PTO. That's why there are so many D-17 PTO levers broken off.....people trying to force in into gear or pull it out of gear under load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 5:47pm
The hydraulic PTO is good for shifting in and out on the go. I liked it for cutting and baling hay. It also has a brake.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 5:55pm
Yes, I can see the benefit of a machine that has it from the factory, the OP is wanting to perform major surgery to an existing machine Wink . What type of damage can/has been done to machinery with the "brake" being applied at the wrong time CryCry ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 5:58pm
There is a "neutral" or coast feature to allow the machine to coast to a stop and then apply the brake. Not major surgery to remove a PTO box and reinstall a PTO clutch box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 8:08pm
If it is a heavy load the brake will slip and slowly stop. I does nut totally lock. It's not as bad as pushing in the foot clutch and hitting the brakes.
This page was generated in 0.727 seconds.
