has anyone |
![]() ![]() ![]() ![]() ![]() Posted: 09 Nov 2020 at 7:37pm |
ever taken apart one of those B&D big batteris that run their drills and saws? can they be rebuilt? i have a few that won't hold a charge anymore and as expensive as they are...
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5059 |
I've rebuilt 12v DeWalt batteries.
Dusty
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6464 |
They can be rebuilt. I buy replacement batteries for my 18V DeWalts from Batteries Plus. One or two year warranty and about half the price of ones from Lowe's. They are Ray O Vac brand.
was at the farm store today (bomgaars) and Milwakee brand has batteries that say it fits all brands for $99. i really don't wanna pay that much for them.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24645 |
I've 'reborn' one my Ryobi 18+ batteries. Screws located under small round 'covers', used dental pick to remove. Those are 'somewhere' in the garage...oopsy.... Small Torkx to open up the case.. depending on the pack, batteries will have nickel plated straps welding them together,so just cut, remove, install new battery and solder them in. The Chinese make/sell fancy baby arcwelders to properly join battery to strap though... Jay
bikley ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Maryland Points: 5406 |
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4723 |
Come on Shameless all this time in quarantine you can study up and become the expert here on "fixing" batteries . There are enough you tubes to get you the whole 2 weeks without much boredom.
thanks Bikley! that tells me lots! i think i'll go that way with these bats. Ray...as soon as i get the heat going in the outdoor kitchen, i'll start re-doing batteries on the work table i gots in there. (right below the TV).
desertjoe ![]() Orange Level Access ![]() ![]() Joined: 23 Sep 2013 Location: New mexico Points: 13692 |
Shameless,,just so you know,,,I did one 18 volt battery pack and it worked great but you gotta have a GOOD soldering gun,,and,,,,no shaky hands,,,,,!! I didn't have either at the time so I ain't done any more,,but it ain't hard for those that gots a lot of time on their hands,,,,,
Add in my email says they can show how to redo any battery from your phone on up to heavy equipment.
JohnColo ![]() Orange Level ![]() ![]() Joined: 03 Apr 2020 Location: Niwot, CO Points: 1263 |
Yeah, and how much the emergency room visit cost! lol
tadams(OH) ![]() Orange Level Access ![]() ![]() Joined: 17 Sep 2009 Location: Jeromesville, O Points: 10866 |
I found batteries for $35.00 on Amazon
think i'll try the HF battery exchange first, like what the video that Bikley posted...that seems pretty simple. i gots a top of the line soldering gun...and yes...i know how to use it!
Well,,,,now that you brought it up,,,,I'd like to hear a "fail Safe" procedure for solderin,,,I ain't ever been able to solder worth a Chit,,,,I had to redo most of the engine compartment wiring on the Black Silverado,,so I bought a good top of the line Weller 100/250 gun and STILL fought that sob,,,,,and them solder joints looked worst than a cobbled up gorilla weld job,,,so I used a lot of electrical tape and heat tape to cover up all that meanness,,,,,
Joe...get the wire/connection hot from underneith then touch the solder to the wire, seems to work better with thin solder on small wires, the thick solder is for big wire like battery cable stuff. the thinner solder will suck right down into the wire when the wire is hot, just touch it, and sometimes touch it more than once, don't hold it there or you'll get globs. if you get a glob, sometimes you can touch the blob and spread it out length ways on the wire, otherwise it may just stick to the gun. do the same when soldering wire into the shove on connectors too! it'll usually suck right inside the crimped connector. be careful when you stick your tongue on the connection to test if it's cooled enough to wrap it with tape, it still may be to hot yet.
![]() ![]() ![]() Had a old guy show me the tricks of soldering copper pipe. Clean with fine sandpaper, heat and some acid, heat and put a little paste cleaner and your good to go. Can be a lot harder to clean copper wire. Espley when your cheap ![]() ![]() A friend had a antique Weller soldering gun I learned on. It worked real good so, I went and bought one never had good luck with the dang old thing. So it has to be black majic.
I took one apart and put new cells in it. The China replacement cells were junk. You can buy lithium batteries already in the old 18 volt case I got mine from Amazon. You need a new charger but they work great. You can also get battery adapters that allow you to use new lithium batteries from other tools in it place. I have a large assortment of B&D tools they work fantastic on the new lithium batteries. https://www.amazon.com/gp/product/B07RPNH5J3/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Edited by Dakota Dave - 12 Nov 2020 at 11:01am |
fixer1958 ![]() Orange Level ![]() ![]() Joined: 13 Feb 2010 Location: kansas Points: 2434 |
I had a couple of Makita batteries that the charger wouldn't take anymore. $120 each. I charged them with a 12 volt battery charger car/tractor type charger on boost. Stood across the room and plugged it in. Worked somewhat, I just stayed away from it charging. Finally said the hell with it and pitched it. 15 years old anyway
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87573 |
dont know what VOLTAGE you have, but you can buy GENERIC batteries to fit EVERY BODYS drills.. I buy GENERIC 19.2 V units for my Craftsman drills... Check AMAZON.. probably e-bay also.
OOOPPS... guess DAVE beat me to it... YES, you can buy LITHIUM or the older style NI-CAD if you have the older charger.. and can get different AMP outputs also for the voltage you need.
Edited by steve(ill) - 12 Nov 2020 at 4:37pm |
Michael V (NM) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: NM Points: 2464 |
I bought an adapter for my old Ni-cad milwaulkie tools, now I can put the newer Li-ion batteries on them and they work great. I have heard though, do not leave the battery on the adapter, it will drain it...so I remove the battery when I'm done
well shucks...i better check to see what charger(s) i have before investing in replacement batteries. i have 2 different chargers i have used on all the 18V ones, a small slide on and a fast charger. my 20V charger don't work on the 18V bats. only the 20V bats. dang it!! some of ya'll cornfuse me!
