wiring diagram
Billy Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billy Ray Quote  Post ReplyReply Direct Link To This Post Topic: wiring diagram
    Posted: 08 Nov 2020 at 2:45pm
At one time I had a wiring diagram for an Allis chalmers B with a one wire alternator and a key start ignition and magneto.  Somehow I have lost it but I remembered  ( or thought I did) that I had gotten it from a member of this forum.  If anyone has a wiring diagram for this setup I would appreciate it if you could post it so I can copy it and get my system straightened out.  I need all the help I can get when it comes to electricity.  Thanks,
Billy Ray
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 5:26pm
well, something like this... You have a separate STOP switch for the mag, not part of the key ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billy Ray Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 5:44pm
No, actually the key cuts off the magneto and shuts down the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 7:06pm
use a key switch from an older lawn mower / garden tractor that had magneto ignition.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 9:34pm
if you have the key already, thats great... If not, you need a key switch that has TWO TERMINALS connected when in the OFF position... those two terminals go to the mag and GROUND... You dont use the ON position, ( unless you have headlights ) just the START position for the starter motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 9:47pm
here is a Briggs lawn mower switch.. at the bottom left of the page it says terminals 1 + 3 are connected when OFF... So those would be the 3=MAG and 1=GROUND... It says 4 + 5 are connected in START, but 4 is not connected when you go back to the RUN position... so  5= POWER (12 v) and 4= Solenoid wire .
Edited by steve(ill) - 08 Nov 2020 at 9:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billy Ray Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2020 at 8:33pm
Thanks a lot for the info and the help.  I appreciate this bunch of guys on here.
