Cutting Plexiglass/ Acrylic ?? |
| Author | ||
FREEDGUY
Topic: Cutting Plexiglass/ Acrylic ??Posted: 25 Oct 2020 at 6:47pm |
I've cut a lot of different materials in my line of work, but never plexi/acrylic panels. What is the blade/tool of choice for this project( it's a 1/4" thick panel) for a wind break on a neighbors covered porch. Thanks
The panel will be 4'x8' but I need to cut an angle (the 4' way) to match the roof angle. Edited by FREEDGUY - 25 Oct 2020 at 6:49pm |
| Sponsored Links | ||
Dakota Dave
Posted: 25 Oct 2020 at 7:00pm |
Go to menards and get a plexi knife. It looks like a little hook blade. Put your straight edge on it and score it a couple times flex it and it'll break a the line. That is the cleanest way to cut plexi. You can tape it and cut with a sabre saw with a very fine blade. You'll have to sand smoot after cutting with a saw
FREEDGUY
Posted: 25 Oct 2020 at 7:11pm |
Thanks Dave
, that's where the panel is coming from .
omahagreg
Joined: 11 Sep 2009 Location: Omaha, Nebraska Points: 2806 |
Posted: 25 Oct 2020 at 7:37pm |
A 40 tooth circular blade does really nice!
Greg Kroeker
1950 WD with wide front and Freeman trip loader |
FREEDGUY
Posted: 25 Oct 2020 at 7:42pm |
I have a few of those, does the blade need to be installed "backwards" like cutting vinyl siding ?
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9668 |
Posted: 25 Oct 2020 at 7:54pm |
I usually use a cutoff wheel on a 4.5” angle grinder. Tape and mark the cut line on the tape.
HD6GTOM
Posted: 25 Oct 2020 at 8:00pm |
The lumber yard I worked for had us replacing glass in windows. We would use clear tape on both sides of the plexiglass and a very very fine toothed jig saw blade. We had 2 pieces of plywood layd down, almost butted together supporting the plexiglass the saw blade went between the two pieces of plywood.
Grayray
Joined: 12 Sep 2009 Location: Ambridge PA Points: 3858 |
Posted: 25 Oct 2020 at 9:18pm |
No. Just cut it like you are cutting plywood. The more teeth the better. I use a plywood blade, but have used a 40 tooth blade without any problems.
omahagreg
Posted: 25 Oct 2020 at 9:36pm |
Not necessary to run it backwards, but it would work fine and probably be better! I dont, I'm usually in a hurry...!
Greg Kroeker
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24767 |
Posted: 26 Oct 2020 at 5:32am |
80 tooth blade works very well, though I get a friend to 'cut and supply' when I have to use it. He owns signshop..... When you're done cutting, use a propane torch to 'fuse' the cut edge.No need to sand then. Do NOT try drilling holes in it though ! It'll shatter crack, unless you use 'special cut' drill bits and STILL go slow,not so slow the plastic melts into a blob and not too fast to crack it.... I use Polycarb instead of Acrylic. Poly is easily drillable AND you can tap the holes. Cuts GREAT too...... supposedly bullet proof though I've never tested that 'property'... Jay
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34295 |
Posted: 26 Oct 2020 at 7:12am |
I used clear packing tape where wanted cut line, set that edge on a sheet of plywood supported on saw horses on cross lumber to keep flat, mark the line set a straight edge for a circular saw set SHALLOW, 80T blade and walk it thru not drive it thru with a pair of hands holding the offal piece, remove tape off BOTH sides and used 600 sand paper to feather the edges
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12243 |
Posted: 26 Oct 2020 at 7:40am |
If you ever need to drill it, use a UNIBIT step drill bit. Works amazing, no grabbing or chipping or anything, smooth sailing.
john(MI)
Posted: 26 Oct 2020 at 11:45am |
KKeep the edge where your cutting close to the edge of what its laid on. Be very careful drilling near the edge. I've had the best success with a jig saw. Go slow!
FREEDGUY
Posted: 26 Oct 2020 at 6:59pm |
DMiller, you have no idea of the grin on my face as to your "offal" reference
![]() . Pretty sure that not many on here know what that means ![]() . Thanks for the reply . And thanks to ALL that replied ![]() . I never dreamed plexi was a bi*%h to drill though, good to know . |
Posted: 27 Oct 2020 at 5:01am |
Been using that since taught it by Grandfather, ?60 years?. Refers to the Off Fall Material when cut anything so become a standard word offal.
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4946 |
Posted: 27 Oct 2020 at 11:04pm |
My grandfather used the term " swarth "as the material a saw or drill removes as it works
German heritage maybe ? Edited by Pat the Plumber CIL - 27 Oct 2020 at 11:05pm |
