D 15 SMV sign
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 SMV sign
    Posted: 21 Oct 2020 at 11:46am
Just wondering where you fellas put your sign , if you have one ? My seat base ( left of the seat ) has a couple 1/4" holes that I might could use . I sometimes drive around the neighborhood and don't wanna get hit . THANKS !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 4:27pm
In my opinion, if they can't see an Orange tractor, they won't see the sign! , but the law is the law. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 4:44pm
You're exactly right Tracy . I just wanna try to play it as safe as I can . Be my luck I'd get fined for not having the sign . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 5:20pm
Make a bracket that uses existing holes. Save your sheet metal Those two holes you mentioned will work fine.Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 5:33pm
I use the 2 holes you mention, or simply hang it wif a piece of balin wire...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 6:12pm
I have a plan that might work . Just wanted to see how everyone else mounted their sign . Thanks
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 8:26pm
I have added this adapter to my 3 point hitch fastened to the top link along with the SMV sign.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 8:44pm
A sign tied to the seat suspension with a piece of baler twine is what I use.  Easy to put on, easy to take off.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2020 at 12:10am
Been there a while bu it works just fine.  Not too sure you can find this type of mount any more.
Edited by john(MI) - 22 Oct 2020 at 12:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2020 at 6:24am
Thanks for your help guys .
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2020 at 6:56am
The federal law that authorizes the use of the SMV sign on vehicles travelling under 25 MPH on public roads requires that it be mounted 4'to 6' from the ground on the rear of said vehicle. This has been law since the early 70s.
