Wood for idler blocks |
dr p
Orange Level Joined: 24 Feb 2019 Location: new york Points: 1151 |
Posted: 19 Oct 2020 at 6:20am |
Finished filling crib this weekend. Started putting picker away and I noticed the wooden idler blocks are the elevator drive chains are done and I am sure they are nla. What wood do you think I should use to fabricate new ones?
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22823 |
I have plenty of available Osage Orange, commonly know as Hedge, that would work for a LONG time. Any kind of Oak would do, or maybe Ash. Some Ash is much finer grain than others. The finer the grain, the longer it will last IMO.
A few years back, I had a bearing out of my 6 foot 3 point disc. I was thinking of using hedge, but had a mulberry branch by my deer stand that seemed to be about the right size, so I made the new bearing out of mulberry. Probably not the best wood for a bearing, but it will last as long as I need it to. |
truckerfarmer
Orange Level Access Joined: 26 Jan 2013 Location: Watertown, SD Points: 3217 |
Did you soak it in oil before using, or did you install it dry.
I have a project I'm building that I'm considering using pieces of 3" x 4" oak blocks for the bearings on 1 1/4" shaft. |
JoeO(CMO)
Orange Level Joined: 11 Sep 2009 Location: Cent Missouri Points: 2694 |
Hedge, oak, other hard wood, cut in shape of a half moon key, soak in oil.
Also wood bearings in the old MM disk, had a pair and that hung in the shop for the pattern. A rotary hoe I had had wood block halves for bearings
Edited by JoeO(CMO) - 19 Oct 2020 at 7:13am |
Orange Level Access Joined: 12 Sep 2009 Points: 20496 |
Years ago, the Gleaner wood blocks practically dripped oil on the parts room shelves. Some batches were oilier than others.
darrel in ND
Orange Level Joined: 22 Nov 2009 Location: Hebron, ND Points: 8634 |
I've been making idlers out of high density plastic. (the white stuff) Seems to work good and last a long time. Darrel
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3728 |
Lots of wood bearings still available for red combines. Some for the grain elevators might even work for you, with or without minor mods. I think they are made out of some sort of hard maple, oil impregnated.
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 22460 |
epay (sp?) some SA hardwood, tougher than nails( yeah you MUST predrill holes !!!). some use for decking...
dr p
Found a scrap of white oak, got a neighbor to cut it on his band saw and it is soaking in oil as we speak. Never heard it called a hedge tree before. Here in politically correct New York we use to call them monkey ball trees, but I wouldn't say that out loud any more.
dr p
Thank for the advice
LeonR2013
Orange Level Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Believe it or not but you could also try sycamore. When dry it is tougher than oak.
Carl(NWWI)
Orange Level Joined: 13 Sep 2009 Location: NW WI Points: 954 |
When I redid an all crop 90 with a corn head I used white oak. A small table band saw and some drill bits and your done! Only thing I didn’t do was soak them in oil. Was in a hurry trying to get the project done. But the chains get oiled heavy anyway.
Dakota Dave
Orange Level Joined: 12 Sep 2009 Location: ND Points: 3938 |
When we rebuilt an old case ground driven manure spreader wer used white oak had lots of it on the farm. Soaked over night in hot used oil before installing. They held up for 20 years when it was sold they still looked in good shape.
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2939 |
And Sycamore has no real grain,if you try to split a piece its very tough to do, dogwood is also very hard wood.
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 31070 |
Rock Maple is another, build miter boxes of it as harder than times in 1929.
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4664 |
My dad and grandfather always used hickory.
nella(Pa)
Orange Level Access Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3102 |
Find someone's firewood pile and ask for a piece of oak and make your blocks. If you don't have the tools to make them for the cost of shipping I will if if you email a sketch with dimensions.
Trinity45
Orange Level Access Joined: 17 Mar 2014 Location: Kentucky Points: 1684 |
I agree, Oak or Ash are common enough and should do a good job, I know someone mentioned Osage Orange, that is a really hard wood and used to be used as the pin in post frame buildings.
Brian F(IL)
Orange Level Access Joined: 14 Sep 2009 Location: Paxton, IL Points: 2698 |
I remember pulling them out of the parts bins at Dad's dealership. Some would almost drip oil they were so soaked. Seems like sometimes they came in bags that would be oil-soaked.
DanD
Orange Level Joined: 11 Sep 2009 Location: WI Points: 856 |
Oil soaked oak seems to run forever. My dad's F3 has white plastic blocks on it. Seem to work very good as well. Did Gleaner change over to the plastic or did someone add these?
sparky
Orange Level Access Joined: 13 May 2011 Location: So. Indiana Points: 1547 |
I’ve used dogwood for mandrel bearings and worked fine.
Edited by sparky - 20 Oct 2020 at 10:20am |
CTuckerNWIL
I did not soak it in oil. I made the bore about .030 bigger than the shaft, and cut a groove from the grease zerk, out both ways, to within a half inch of the end of the bearing. Put it together and pumped it full of grease. I'll never wear it out in 20 years of use. I only use it for a couple gardens and a couple acres of food plots. |
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29781 |
Edited by Lonn - 21 Oct 2020 at 2:48pm |
Wink I am a Russian Bot |
shameless dude
Orange Level Joined: 10 Apr 2017 Location: east NE Points: 13607 |
i've always replaced them with the small steel idler pulleys with the 1/2 inch lip on each side. same size holes.
