Header control
groundhog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote groundhog55 Quote  Post ReplyReply Direct Link To This Post Topic: Header control
    Posted: 16 Oct 2020 at 7:39am
We have an R62-1994.  With the header control on and working the reel speed wants to slow when the header adjusts the height. Why?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2020 at 7:57am
Never heard of that scenario before.  I guess in a pinch, I'd get the reel running the speed you want and disconnect the wire to the coil under the cab floor on the left side so it cannot change. If that cures the problem, it is electrical. If it still slows down, it is a hydraulic issue, but I still don't understand what the HHC has to do with it.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2020 at 10:02am
If it has a seat modigual, they can do some crazy things when they go bad. Automatic reel speed could have a problem.         MACK
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2020 at 10:15am
Sure the hoses are tight going from combine to head?
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2020 at 7:52pm
Mack is on to something. When our seat module went bad in our R62 the reel would speed up randomly and then slow down to about nothing. Replaced module $$$ and problem went away.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
