L3 Gleaner
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Topic: L3 Gleaner
    Posted: 14 Oct 2020 at 8:12pm
Harmonic balancer came apart on my L3 Gleaner. I guess radiator and hydro cooler has to come off. Going to need balancer and fan. Any tips to doing this
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2020 at 8:41pm
If I remember right, there is room to get it off without moving radiator.
When you install new one, make sure shaft and hub is clean and dry. Torque bolt to 220 ft lb.           MACK
PS. I may have a used fan and balancer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2020 at 8:51pm
I don’t think I can get a puller on it as the outer part has walked out to the fan shroud. The fan hit the damper pully and ruined it
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2020 at 1:40pm
That radiator is one heavy #$%^%$#@
Wink
I am a Russian Bot
This page was generated in 0.127 seconds.
