XT190 seat
WD in Australia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD in Australia Quote  Post ReplyReply Direct Link To This Post Topic: XT190 seat
    Posted: 02 Oct 2020 at 5:56pm
Any ideas on best place to buy replacement bottom and middle sections for XT190 seat? Any thoughts on good quality sellers would be appreciated.
WD(NF), WD45(WF), WD45D(WF), XT190D(WF), Model U, Gleaner C, All Crop 60, Rotobaler
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2020 at 6:24pm
I can get you plain white or black and white cushions
phil
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2020 at 6:51pm
DJ's that has adds on here has the cushions, either wood or metal backing. Just costs more for the better metal ones. Inside a cab the wood should last for years.
$200 for all 3 cushions on wood backing.
$380 for all 3 cushions on metal backing.
They also have all the parts to rebuild the suspension on that super deluxe model seat.
 I've rebuilt 3 of these in last 2 years. Made the pins, cut bushings from bulk stock, repaired lever that is on bottom of shock absorber the bushings in it wear thru and then pin cuts into lever. I usually weld steel tubing in that fits the OD of bushings, rather than replace lever. , rebuilt 2 of seat frames. It gets expensive but I'll never wear them out again, and they ride SO much better. Their prices look HIGH but if I paid shop labor rate for making / fixing parts would be about the same, and I've another day or more in invested
 a set of pins, #DJSPINSET @ $60.00
 a set of bushings,  #70227910 @ $29.75
 a hardware kit, #SEAT001 @ $12.75 w/ 2 washers, 6 rollpins, 2 clips.
 seat shock absorber, #AC-2190 @ $107.50.
 the frame the cushions attach to, #70243509 @ $265.00
 lever/arm that shock attaches to.  ??
Other venders here also have the cushions as do the online and catalog places.
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2020 at 7:15pm
I bought the more expensive seat cushions from DJ's and the pins and bushings. I was happy with all the parts I got from them. You can look them up online.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD in Australia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2020 at 5:51am
Thanks for the help guys. Will have a closer look under the seat to see what what else might need doing. Tractor has only done 2900hrs so might still be okay.
