Hydraulic Question 7045
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Question 7045
    Posted: 25 Sep 2020 at 7:23am
Man the search feature on this forum sucks.....
Wasn't too long ago, there was a topic about electric over hydraulic controls on a chopper.
You have to run the hydraulics engaged all the time, then a solenoid valve bank actuates various hydraulic circuits. Seems it was mentioned that it's not a good idea long term to bungee cord the lever back, and that there was an adjustment to prevent it from kicking out of the detent position.
Can someone help explain that please?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 7:26am
Remove the small rubber plug at the back of the valve. Insert correct size allen wrench with valve in the hold position. Hopefully the screw isn't rusted solid. Tighten down until the lever won't kick out anymore. Failure to do this creates a 2 to 3 GPM oil leak which heats the hydraulic oil hotter than it should be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 8:13am
Thank you doc.....So, one person standing behind the tractor adjusting screw, one sitting in the seat putting the lever in hold? At least that sounds the easiest?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 8:45am
Engine off. Lever in HOLD. One man at the rear with allen wrench.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 9:10am
Oh. So, sort of an adjust, test, repeat scenario. So, can you "Over do" it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 9:16am
I hope the screw will turn for you. After 40+ years of not being adjusted, who knows??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 9:56am
Yeah, I hope so too. Who knows.
So, adjust, test repeat, that's the right track? Be a few hours before I attempt, perhaps even tomorrow morning. But thank you for your help, as always, Dr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 10:40am
I'd give it a 1/2 turn to begin with. Start the engine and pull the lever into raise. If it stays locked, you are probably good to go. 1/4 turn at a time after that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2020 at 10:45am
Awesome. Thanks again. I know it's a simple thing, just never been there before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2020 at 11:31am
Once I figured out how small the little screw was, worked like a charm. First adjustment was all it needed. Thanks so much!
Guessing I should adjust it back if I want kick out for other things.
Now I just have to figure out why it won’t swing over to the wide position. Everything else worked perfect.
