Henderson Bucket
CAPTMARCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAPTMARCO Quote  Post ReplyReply Direct Link To This Post Topic: Henderson Bucket
    Posted: 16 Sep 2020 at 9:54am
Gentlemen,
   I saw a guy selling a henderson bucket setup that he had on his B, curious if I can use that same unit on my CA?  Anyone know anything about this type system or if it's worth it on a narrow front?  I know the pump goes on the PTO and it's relatively self contained but I know nothing else about that system.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 7:52pm
The framework is most likely a little different for mounting on a B than what it would need for a CA, however it probably could be modified to fit.  A loader is the one thing I would never again have on a tricycle tractor.  A tricycle will push around too much in the mud compared to a wide front.  The CAs hydraulics would be more than adequate for the loader if the cylinders are made for the higher pressure.
Ricky D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ricky D Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 8:28pm
Henderson cylinders take CA hydraulics, I blew the end out of one on a friend tractor when I was a teenager. After he warned me not to go to the top. That was a loader he took off his B w/charlyn pump, & put on the CA
