D10 Pto help |
Bronze Level Access
Topic: D10 Pto helpPosted: 08 Sep 2020 at 10:03pm |
I have a series III with live pto.The pto seal leaking so I took plate off
To get to seal.The pto shaft moves up and down about 1\8" .What is going on here?What am I getting in to get fixed? Thanks, Chris |
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54699 |
Posted: 09 Sep 2020 at 4:40am |
Question: This movement you mention, is it movement by hand, meaning with the engine off, can you move it that much? or does it move that much, with the tractor running and PTO engaged? Can you feel a surging, in the PTO lever, as you engage/disengage PTO?
Bronze Level Access
Posted: 09 Sep 2020 at 5:51am |
Movement by hand when off,if you hold the engagement lever all the way forward or back it tightens up.Is this normal
Posted: 09 Sep 2020 at 6:08am |
Its a long shaft, with a short coupler, up front, so movement by hand is normal. Spin the outboard bearing, see if it feels gritty, or unusual. I wouldn't worry about it too much...
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
Posted: 09 Sep 2020 at 9:21am |
The pto shaft is 2 parts, the one that sticks out that you hook things to, is short. It goes into a damper housing, then there is a long shaft that goes from that damper housing to the fly wheel/engine crank.
That damper housing has 2 fiber, half moon like, parts. They were missing on my D-10, and I could not find any, new or used. Somewhere I fount one, needs two. I did find some martial to make them. I would think that you better take the PTO cover housing off and check things out. If you find that you need a pair of those, parts book calls them dampers, I can make you a pair. Dusty
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10870 |
Posted: 09 Sep 2020 at 11:30am |
Dusty, can you post a pic of dampner? I have seen one, but wondered if it were correct. Thanks Tracy
Dusty MI
Posted: 09 Sep 2020 at 12:19pm |
Tracy, PM me your e-mail add. I'm not good at posting pictures on here.
Dusty
