F2 Traction Belt?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: F2 Traction Belt?
    Posted: 15 Aug 2020 at 4:59pm
I was out at the farm today to "fire up" the equipment. I started looking at the traction belt that goes from the main counter shaft, over the "idler" pulley and down to the tranny input . OMG, if that belt needs replacing, how does it get "squirreled" onto the tranny pulley with the brake mechanism within an 1"of that brake assembly ??
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2020 at 9:00pm
It will go, just takes so effort to squeeze it through.         MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2020 at 1:21pm
Like MACK says...you haven't ask the important question about getting it off the pulleys.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2020 at 2:35pm
Its a - WHAT WERE THEY THINKING - deal,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2020 at 4:45pm
Luckily it's not a needed repair, I just happened to look down and noticed how close the pulley was to the brake "tower" Smile. In hind site, I think the variable speed is in the "upper" end of the speed range, so I "assume" that in a slower range, the pulley will bet a little farther away Big smileBig smile ?? Thanks guys
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2020 at 9:20pm
No, outer stays same place, inner moves.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2020 at 5:26pm
Mack, I wondered about which sheave moved on the "bottom end" Smile I just can't imagine "jamming/contorting" a brand new belt between the outer sheave and that brake tower Confused . Thanks for the reply Wink. Any idea of how much hydraulic fluid, if any, would be lost when disconnecting the "upper" end of the drive system  to get the belt over THAT pulley ??
Sadly, I'm the one that has greased the 2 fittings on the lower end for the past 12 years and NEVER noticed the clearance until this past weekend CryCry
Edited by FREEDGUY - 17 Aug 2020 at 5:29pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2020 at 8:51pm
Fluid loss is a small amount.                MACK
