7020 steering cylinder
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: 7020 steering cylinder
    Posted: 16 Jun 2020 at 9:07am
Hello everyone. I bought a 7020 project and its missing the steering cylinder I have located one they say they have two sizes ones more like a 2 inch and the others a 1 inch diameter. I am wondering what one I need? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 9:52am
Any 2WD steer cylinder from a 7010 thru 7080 or 8010 thru 8070. NOT A FWA CYLINDER.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 1:06pm
In other words...avoid the 7000 light duty axle cylinder. (and any FWA cylinder)
It has (or could have) the smaller diameter one as an option.
nanuk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2020 at 6:05pm
regarding the steering cylinders, my 7060 sprung a leak...  rapid drip/sometimes a steady stream depending on the steering pressure.
are their repair kits available?
Are the seals generic?
what is the best way to approach this?
Time is short at the moment, as I am in the middle of baling!
AC7060Pd 1975
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2020 at 6:32pm
Yes, you can get a seal kit from Agco.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2020 at 9:33pm
7000 uses different cylinder than 7010 and up.         MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 4:05am
Thanks Guys
Glad you're all here!
AC7060Pd 1975
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 8:54am
Just a heads up for YO2000
the cylinder from a 7080 fits my 7060 exactly as original.
Listen to DrAllis
AC7060Pd 1975
