200 Temp Gauge
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Topic: 200 Temp Gauge
    Posted: 01 Aug 2020 at 9:27pm
I bought a new coolant gauge and sending unit for the 200. Not really sure how to wire it up. Old gauge had two terminals + and -. New one has three terminals one marked 12v and the other ones negative. When I hook up the hot wire from the fuse to the gauge at the 12v post something pops in the switch and I lose power to the fuse. Not sure what’s going on but the main question is how to hook up the new gauge.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 7:40pm
12 volt from the switch ign. terminal. The minus to the sending unit. Should only have power with switch on.
If it pops at the switch there is a short somewhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 8:19pm
The third connection is to go to a ground. It is DIFFERENT than the original design.
