D14 headlights
ACCURT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACCURT Quote  Post ReplyReply Direct Link To This Post Topic: D14 headlights
    Posted: 26 Jul 2020 at 12:29pm
I'm in the process of converting my D14 from 6 volt to 12 volt, and I am needing new headlights. My 6 volt bulbs are a sealed beam that measure 4 3/4" round and are held in with a lock ring wit a screw tightener. I can't find a replacement for this bulb. Does anyone have a source? I did find a glass lens and reflector that uses a replaceable bulb that looks like it might fit. Is that the only option?
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 1:03pm
Steiner Tractor or All States have them I believe.
D17 Series 1
Allis B- 1939
Allis B- 1945
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 1:07pm
The D-10 series III came from the factory 12 volt, it's a sealed beam Part #230252.
Will it fit ? I don't know. Could measure mine.
Dusty
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 5:26pm
If your 6v sealed beam have two connectors.  Run 12v to one connector, run a wire from the second connector on that bulb to one connector on the other bulb and a wire from the last connector to ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 9:56pm
D14s after serial number 19001 are 12 from the factory.  Those head lights are 4 1/2" in diameter.  I got a couple from the AGCO dealer and wrapped black electrical tape around the lip that the ring goes around.
You would never notice by looking at it.
This page was generated in 0.041 seconds.
