Paint remover,,,?? |
desertjoe ![]() Orange Level Access ![]() ![]() Joined: 23 Sep 2013 Location: New mexico Points: 13692 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Jul 2020 at 5:15am |
A couple of weeks ago,, I cobbed onto an Edelbrock aluminum intake manifold for Big Brutus and have finally got around to puttin more assembly time on the new engine for Black Beauty. I had not noticed but the PO had painted the friggin manifold a grey color and musta put several coats of paint on a perfectly good aluminum manifold,,,!!! I got most of it off with my batter powered drill and a wire brush but cannot get into the nooks and crannies,,,,I tried some paint remover but did not even touch the paint,,!! Tried some more and left it on there for an hour but still no dice,,,paint never even got soft. Anybody got any ideas,,?? OH,,,and NO TANNERITE,,Shameless,,,,!!!
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24645 |
seems to me brake fluid attacks paint.....at least on my 67 stang it did..... one of the good paint strippers used in woodworking,the pasty types... be super careful rinsing it of course..caustic chemicals and eyeballs is a bad combo... big issue is WHAT type of paint and how old ? you do need something 'aluminum friendly'.... maybe google 'removing paint from aluminum' ? In the good old days I used CIL high speed automotive paint stripper, Used 2 gallons, yes real Cdn gallons to totally strip off 7 layers of paint off the 57 Willys pickup. top 2 caots were house paint.... sigh... wish I had that truck now...sniff,sniff... |
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8476 |
Joe, Aircraft paint stripper is pretty good. NAPA should have it. Regards, Chris
Edited by Sugarmaker - 25 Jul 2020 at 5:12pm |
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3901 |
Be careful with chemical reactions to aluminum. Since you sanded most of it off already you might try small sanding rolls for die grinders like those used for porting and polishing. While your at it you could port match the intake to the heads.
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 33850 |
Might should rethink the removal of the 'Sealant', later manifolds are already painted to seal the porous aluminum to stop the very metal from seeping vacuum. We started seeing this issue with Throttle bodies on TBI cars mid 90s that got aggressively cleaned and removed the porosity sealants on them, got to checking back with our engine aftermarket suppliers where many 'Anodized' the parts to keep thru wall leaks under control, it is also noted that aluminum carburetors that had been overly aggressively tanked do that same thing as the vacuum leaks over ride the idle adjustment capabilities. They are currently Vacuum Impregnating aluminum castings at the factories where some are just applying sealing materials to the outsides.
Point of note on older cars and trucks with slow leak tires that seemingly cannot be located to repair yet requiring often refills, the rims were sealed at the factory, time, tire changes scuffing, abrasion, corrosion all affect that sealant coating and the darned wheels are the actual leak path.
nay-palm
as Jay says...brake fluid should do it...if not...spray sum aluminum paint over it, or sand blast them!
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9643 |
Brake clean /carb cleaner
Bill_MN ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Bead blast NOT sand blast, it's probably ceramic engine paint i.e. baked on tough as nails. When you get it cleaned down to the bare metal spray it with hi temp engine clear to seal the pores.
Edited by Bill_MN - 25 Jul 2020 at 9:21pm |
weiner ![]() Orange Level ![]() ![]() Joined: 19 May 2012 Location: Cadillac, Mi. Points: 4304 |
DMiller, yes my wife experienced that very thing on aluminum wheels on a 2010 Toyota. After fighting it for 3-4 years we went to steel wheels. Not as purdy, but no more hassel.
Real heros wear dogtags, not capes.
