190XT Hydraulic Fluid Change
BcrazyTH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BcrazyTH Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Hydraulic Fluid Change
    Posted: 13 Jun 2020 at 11:57am
Hi all,
I am getting ready to change the hydraulic fluid and filter on my new to me 190xt SIII. I plan to drain the fluid, drop the sump and clean the screen and then put it all back together with a new filter. My question is, do I need to prime the hydraulic pump before restarting? I’ve noticed some post in other topics mention priming. Any other helpful things I should be aware of?
Thanks,
Ben (Eastern Washington)
WD45
190XT SIII
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 4:45pm
No need to prime the pump. There is no real way to do so. The suction tube will contain some of the old oil.
NoslenroK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NoslenroK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 8:38pm
BcrazyTH>> What type of oil did ya plan to go with?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BcrazyTH Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 9:46pm
I’m going to use NAPA premium tractor hydraulic & transmission fluid, the label states it meets 821XL specs.
WD45
190XT SIII
Post Options Post Options   Thanks (0) Thanks(0)   Quote BcrazyTH Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2020 at 11:15pm
Question, how much hydraulic fluid does a hydraulic fluid and filter change normally require. The book I have states the capacity is 36qts. Surely not all of this is drained right? I didn’t get 36 quarts out the tractor when I drained my fluid, or I missed a sump.
Thanks.
WD45
190XT SIII
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2020 at 7:03am
5 to 5 1/2 gallons usually gets it.
