Ground WD headlights
davegoodell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davegoodell Quote  Post ReplyReply Direct Link To This Post Topic: Ground WD headlights
    Posted: 27 Jun 2020 at 9:37am
I am seeking suggestions to properly ground the headlights for a WD.
Thanks-Dave in Minnesota
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2020 at 10:10am
Lights ground best through thumbscrews. Make sure the threads and ends on the thumbscrews and the holes are clean shiny metal, and also clean off the area of the light post where the thumbscrew tightens down on it. Put a very light coat of dielectric grease on threads and bare spot on the posts to prevent corrosion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2020 at 5:36pm
Take the headlight apart and solder a wire to the outside of the socket. Put it back together and connect the new wire to a GOOD ground source with no paint between the new wire connection and the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote davegoodell Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2020 at 4:29pm
MMMMMM thumbscrew eh?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2020 at 9:22pm
Dave,
 I have had many of these lights not working due to poor grounds. From the bulb contacts to, to much paint where the thumb screw contacts the tube. Use a meter to do a continuity check as you go through the system.
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2020 at 10:06pm
Actually, I discovered the hard way, all the "magic" was in those thumb screws. I really shined them up well and then the lights worked perfect. Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2020 at 10:07pm
Replaced the wiring to mine. Dry insulation and mice had taken its toll. Cleaned up the ground contact points and they have worked well ever since.
Post Options Post Options   Thanks (0) Thanks(0)   Quote davegoodell Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2020 at 10:55am
Would it work to ground it to the metal part of the headlight with a thumbscrew or any kind of screw?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2020 at 3:44pm
Best bet would be to just clean up what is there and use it as it was intended.  Barring that, you could solder a wire from the outside of the bulb socket to anywhere that would make a good ground.  It works, but I prefer the former and it's a lot easier.
Good luck whichever way you choose.
Post Options Post Options   Thanks (1) Thanks(1)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2020 at 7:14pm
 The outside of the bulb socket, HAS to have continuity to the engine block or the frame, best checked at the battery ground. You can do it anyway you want, but if you add a ground wire from the socket, back thru with the 'hot' wire and connect it to a good ground, you'll never have a grounding failure again. You also have to look REAL close to tell it's even in there.
