WD-45 Wide Front |
WDmatt ![]() Bronze Level ![]() Joined: 22 May 2020 Location: South Dakota Points: 8 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Jun 2020 at 10:16am |
What is the difference between the 3 and 4 bold wide fronts? I found a 4 bolt wide front listed on Facebook, advertised for a WD-45. I'm wondering if it will fit.
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34352 |
3 bolt fronts were weaker inthe attachment and some broke out and used on the WD tractors... the 4 bolt front block were tougher and used on WD45 tractors... and will slip right in on the frame rails.
allisbred ![]() Orange Level Access ![]() Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
It must have the bloster to work. Ours always wore out in the hole first, tubing for axle extensions second— have had both 3 and 4 bolts on for extended service( moves 1000# bales daily), not really sure the 4 bolt was any better.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22046 |
Never seen a 4-bolt bracket work loose causing any damage. Have seen dozens of 3-bolt brackets work loose and damage things beyond a good repair short of welding up a new homemade bracket. If you were using a 3-bolt heavily loaded and never had trouble, you were LUCKY.
