unstyled wc questions. |
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9535 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Oct 2010 at 8:39pm |
I just bought a wc today at an auction in OK. It has cast iron (not spoked) front wheels are these ac or somthing else (#71466 1937 I believe). It has pto and a power lift. What is the correct rear tire size (24" solid wheels)? And were all unstyled wc's distilate tractors?
GBACBFan ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Green Bay WI Points: 2662 |
I believe the spoker rears on the unstyled WC's were 10" x 24", if that helps.
are genuine." - Mark Twain |
MNLonnie ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
That serial would make it a 1938 and would have had the 24" one piece steel wheel.
ChuckLuedtkeSEWI ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
Here is a link to the discussion we had a week ago about the unstyled that I brought home. According to your serial number, you should have disc rear rims on it. I have a set here, but we're worlds away. They only used them for a year or two? I think. I can't find my book with all the WC differences right now.
Yes it is the 24" one piece rear wheels I would like to know what size of 24" rear tire is correct? It has grader tires on it right now. And are the solid cast 5 bolt front wheels original? They seem like wheel weight wheels.
11.25X24 is what they were back then. When you say solid cast wheels I start thinking wheels off of a Speed Patrol which would explain the grader tires.
Put a pic on here of the cast wheels. They could be Case rims. They fit on allis five bolt hubs.
Larry in OK ![]() Orange Level ![]() Joined: 25 Jan 2010 Location: NE Oklahoma Points: 315 |
I found out after you let that the rear tires were probably bought used from the county.
Have you tried to take the front tire "slippers" off yet? |
Some people are like Slinkies. Not really good for much of anything but they still bring a smile to your face when you push them down a flight of stairs.
acwdwcman ![]() Orange Level ![]() ![]() Joined: 16 Oct 2010 Location: palmyra, il Points: 1075 |
they are probably right if it is a 38 becuz i used to have one but i traded for a 37.,
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22823 |
Sounds like WC speed patrol front wheels to me too. I guess the speed patrol didn't have the 5 bolt pattern.
Edited by CTuckerNWIL - 17 Oct 2010 at 12:54pm |
An 11.25-24 tire back then is a 14.9-24 in today's numbers.
You got me, I don't know what those front wheels are?? They almost look like some industrial type.
Mike Sanwald ![]() Bronze Level ![]() Joined: 11 Sep 2009 Location: Lebanon, Mo. Points: 4 |
Those are front rims off a CASE SC. I put them on mine if I need extra weight on my WC pulling tractor. Mike
Mike wins the cupie doll, SC Case. I don't know what they weigh, but they are heavy!
