WD45 Wide Front End ??
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Wide Front End ??
    Posted: 16 Oct 2010 at 4:18pm
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 5:52pm
looks like a farmall
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 6:12pm
 Looks like a schwartz. You see many of these bolted to U MM's. all you did was bolt the front end on the tractor. Took off the narrow front spindles and bolted on a arm that goes to the tie rods. Most wide fronts on Farmalls is a Schawrtz. The factory Ih front ends weren't that good so most of them were changed.
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 6:32pm
Nord frontends  look like that too.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 9:28pm
Those don't look like Schwartz parts to me. Tube maybe. Spindle arms and tie rods NO.
Jim in SE ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim in SE ND Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 9:33pm
Speeco made fronts that looked like that, had one on a M farmall, pretty lite duty if that is what it is.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 9:56pm
either way it looks like a turd for 1000 bucks....
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 9:58pm
That little tank under the hood and the parts that go with it are probably worth more than the rest of the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 5:57am
is that powersteering? I cant see it very well but after you said that Lonnie I enlarged the pic....too bad they want so much for it....I have a good block and access to a narrow bolster....that thing looks pretty dumb with that WF
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Pa.Pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 7:30am
Not sure on the front end but I can see the shifter and it's not a wd45.
ChuckLuedtkeSEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 8:01am
I agree Lonnie.  I missed out a month or so ago on a WD45 with factory power steering that was tight with good rear tires for $700.  I figured it was a deal as you'd pay $500 for the complete power steering setup alone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 2:16pm
yeah it does have a straight shifter....must either have a WD shift tower or its just a WD right?
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
John In. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John In. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 1:48am
 That's a schwarts frontend , had one on my tractor but changed it to NF. The side plates look different though.  John
FredinInd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredinInd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 7:16am
It's a Schwarts, have the same one on one of my 45's. Tubes are a lot more beefed up than the stock AC wide fronts on 45's.
