100 Series 7'th gear ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: 100 Series 7'th gear ??
    Posted: 04 Jun 2020 at 7:29pm
Was there a "field" use for the  7'th gear; 4'th gear/low range ?? Now that I think about it, how about the D series Wink Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 7:32pm
10+ Mph in the field?  I've never done that!  4th Gear in general is more of a road gear be it high or low range to me.
bauerd44 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bauerd44 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 7:38pm
At about 1/2 throttle, or 5MPH I used to rake hay to initially turn it over to dry better.  I did wish for a 5 speed many times for more speed selections.
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 7:50pm
 I just assumed that there was a reason for that particular "gear" LOL !! I can understand the 8'th/road gear though, perhaps 7'th was easier on the driveline to get there ??
What about rotary hoe work ?? I've been told that the "faster-the better" ??
Edited by FREEDGUY - 04 Jun 2020 at 7:52pm
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 8:07pm
Spent most of today on a D17, 4th gear low range raking.....maybe 1/4 throttle. 3rd gear hi, full throttle, as the field got "smaller"
Edited by Stan R - 04 Jun 2020 at 8:11pm
orange200 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange200 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 8:45pm
We used to pull a 4-section drag cart in 4th low with the D17.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 8:57pm
About right for a rotary hoe.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 10:55pm
I doubt the engineers had 4th in mind when they came up with the concept of 2 speeds in one gear. It was for more selection in "field gears". Fourth just benefited as a tag along.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2020 at 6:04am
When I "hit the road" with my XT, I have never, ever, took off in fourth gear high range (aka,8th gear). I'll always get rolling in 7th gear, then put the PD ahead for 8th gear. Seems a little easier on everything, especially if you have much of anything behind you. So, with that being said, in my mind, 7th gear has a purpose. Darrel
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2020 at 6:05am
On a D series 4th low is just right for carrying hay bales around in the field or when pulling loads on hills up and down on the  road it was handy to shift to low range.On the 100 series the ratio between high and low was too close not nearly as useful.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2020 at 7:12am
Dad used to round bale at lower throttle speed in 4th low with his XT. We used to rake in 4th low with the D17 and for starting a load on the road, 4th low worked better than starting in high. I agree with Darrel, 4th low had a purpose and it worked good.
Wink
I am a Russian Bot
This page was generated in 0.130 seconds.
